Old 04-13-2012, 11:16 PM   #1
Changing color of existing finish on stairs
I was wondering if there was to darken the color of my stairs and handrail to an ebony color without completely stripping and sanding them down. I would like them to be dark but not entirely opaque. Would adding some type of black dye to polyurethane allow me to achieve these results? I would definitely do a light sanding of the current finish before applying. If so, what type of dye/poly to use?
Changing color of existing finish on stairs-stairs.jpg   Changing color of existing finish on stairs-stairs2.jpg
designSTL is offline   Reply With Quote
Old 04-13-2012, 11:50 PM   #2
Dark colored stairs would be a trip hazard.
Old 04-14-2012, 04:51 AM   #3
paper hanger and painter
chrisn's Avatar
chrisn is online now   Reply With Quote
Old 04-14-2012, 02:56 PM   #4
sdsester's Avatar
Originally Posted by chrisn View Post
Ditto!
You might try a gel stain over the surface prepped as you mentioned and see if you like what you achieve. You will be using it more as a glaze than a stain. Layer and don't try to go as dark as it sounds like you want in one pass. You will need to poly over it. It will take you awhile and unfortunately, gel stains are not cheap.
sdsester is offline   Reply With Quote
Tags
pigments, refinishing stairs, stain poly
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Building Code Requirements: Basement Stairs (Quantity) dutchswan0311 Building & Construction 27 09-19-2011 07:13 PM
Water leaking down outside concrete basement stairs handlethis Building & Construction 3 08-06-2010 04:49 PM
Basement Stairs/ EZ Stairs mjkpainting Carpentry 8 02-24-2010 10:24 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 07:11 PM
