Changing Chimney Color - Painting - DIY Chatroom Home Improvement Forum
Old 10-24-2011, 07:27 AM   #1
Changing chimney color
I have a red brick chimney that runs up the side of my house. My house is tan & dark brown. I want to darken the brick to a deep brown, but still want it to look like brick. I've seen painted brick(usually lighter) but it looks like paint. Could anything be done?
Donnakup is offline   Reply With Quote
Old 10-24-2011, 10:22 AM   #2
Gymschu's Avatar
Rewards Points: 480
About the only thing you can do is paint the individual mortar joints in a suitable color to match the brick........gonna be a lot of work, but, as far as I know that's the only way.....
Old 10-24-2011, 10:51 AM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Not sure but there may be stains that could be used. I'd try googling masonry stains or something similar.
Old 10-24-2011, 08:56 PM   #4
The problem with painting brick is that it looks like painted brick. It's the same reasoning behind painted tile, paneling, or any other surface that has joints. The reason is the painted over mortar joints, in the case of brick. There are only two ways to do it, either paint each brick individually or paint entirely and stripe the mortar with a white or very light gray, and even the second option looks like painted mortar, not natural. If the joints are concave, as opposed to flush, you can use a very short nap roller and carefully, slowly, roll over the brick without hitting the mortar. I've been party to both methods over the years, and both are tedious, time consuming jobs. Why doesn't red brick look good with tan and brown? I would think that looks sharp. I think it's probably looking a little better to you at this point, lol.
Joe
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Paint color tone changing in colors richwill Painting 2 09-13-2009 11:10 PM
Changing exterior color of house docsullivan Painting 3 08-15-2009 12:42 AM
changing cabnit color anji Carpentry 4 10-12-2008 11:48 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 04:12 PM
