Old 04-04-2009, 05:27 PM   #1
chalky primer(preprimed) door trim
the new back door I had installed a couple months back. the trim on the exterior and in the middle(where the door covers) is really chalky.
simply rubbing my fingers across it will cover them in white chalk. I wiped them down with a damp towel and tested them the next day - still chalky. Is this normal? will painting over it cause adhesion issues? I want to paint it with a latex.
newbpainter is offline   Reply With Quote
Old 04-04-2009, 06:56 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
It is not unusual for pre-primed to be chalky
That's why most pros will prime "pre-primed" trim
Since it's very chalky, and a few months installed, I'd suggest (re-)priming with Zinsser's Gardz before painting
slickshift is offline   Reply With Quote
Old 04-04-2009, 07:12 PM   #3
I figured that I would have to reprime the preprime. The preprimed is also cracking and bubbly in some areas. I wish they wouldn't have primed it at the factory in the first place! Thanks for the tip on Gard; i researched a little and its seems to be highly recommended by pro painters.
painted fascia has chalky fog-like marks that come and go bug Painting 3 02-10-2009 11:35 AM
