Cetol Dek Finish - Painting - DIY Chatroom Home Improvement Forum
Old 05-06-2012, 05:11 PM   #1
cetol dek finish
Im trying to restain a deck that has cetol sikkens dek finish on it, as i was bleaching it getting ready to pressure wash i notice stain was breaking up all the way back to bare wood in places all over the deck.so as it dryed i went back 2 days later to sand feathered all lose edges of stain flush i had bare wood on places covering the whole deck floor and top handrails so i put one coat of cetol dek finish on floor and hand rails the prevous stain had darken with time as it always does with this product.so now i had light spots every where what can i do to solve this issue would prefer answer from some one whom actually has used and knows this product thanks for any help.
here4funnow is offline   Reply With Quote
Old 05-06-2012, 06:20 PM   #2
(the original)
Rewards Points: 756
Cetol is a good product IF you read and follow the instructions:
"Previous coatings must be removed prior to the application of Cetol DEK Finish."
That includes old coats of Cetol.
You'll need to strip the whole thing and start over.
ratherbefishin' is offline   Reply With Quote
Old 05-06-2012, 08:09 PM   #3
Rewards Points: 150
Got to love Sikkens , it means money to me. Strip it, neutralize then coat it. Not a job for the amateur.
CaptRandy is offline   Reply With Quote
Old 05-07-2012, 06:51 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
The product generally doesn't break up like that if it's been applied and maintained correctly to begin with. Once it does get to that point you have to strip it before restaining. It isn't the easiest thing to strip either.
Darkling Designs
poppameth is offline   Reply With Quote
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Finish Stripper or No Finish Stripper starkhd Painting 11 02-16-2012 07:15 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 07:11 PM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 07:23 PM
