Ceramic Tile - Painting - DIY Chatroom Home Improvement Forum
Old 10-02-2007, 11:36 AM   #1
ceramic tile
I just recently moved into a older home in which the previous owners painted the original ceramic tile in the bathroom, they did a horrible job and it is thick in places and runny in others, my question is how to remove the paint from the tile without ruining it because it is a really nice beige color.
vmiller23 is offline   Reply With Quote
Old 10-02-2007, 12:19 PM   #2
I have a blower type thing someone gave to me... it suppose to remove paint by heat blowing ... may be you can try somthing like that....
KUIPORNG is offline   Reply With Quote
Old 10-02-2007, 12:44 PM   #3
Rewards Points: 506
I would expect a heat gun and some tedious scraping would take care of the tile itself, but I don't know how on earth you can get the paint out of the grout. I expect a re-grouting would be in order here.
SirWired
sirwired is offline   Reply With Quote
Old 10-02-2007, 07:42 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
Unfortunately, if they did the job even partly properly, it will not leave you with a nice surface, even if you could get the paint off w/o using abrasives
Their is also the potential problem that a huge proportion of tile paintings were as a 'cheap/quick cover up" of another problem, so removing the paint could expose another unknown problem
Especially if it was the home sellers that did the tile painting
I would recommend doing what the tile painter should have done, and have it retiled
slickshift is offline   Reply With Quote
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
stains on ceramic tile sdgoss Flooring 4 09-19-2008 06:19 PM
Joining carpet and ceramic tile rooms TedT Flooring 10 05-21-2008 08:25 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 02:26 PM
