Ceiling To Walls - Painting - DIY Chatroom Home Improvement Forum
Old 03-13-2011, 02:29 PM   #1
Ceiling to Walls
How do you paint the ceiling without getting some paint on the walls or visa versa without using the blue tape? The blue tape pulls off the paint.
jhschott is offline   Reply With Quote
Old 03-13-2011, 03:05 PM   #2
Experienced
Jackofall1's Avatar
Welcome jhschott, to the best darn DIY'r site on the web.
Practice, Practice, Practice and a really good brush. My selection Purdy, 2" angle brush.
Mark
Old 03-13-2011, 03:29 PM   #3
Welcome, firstly it's far more difficult to cut a ceiling into the walls and it's usually noticeable that was done. The ceiling should be done first, overlapping down on to the walls. I have a tutorial on cutting in without tape, it might be useful http://www.diypaintingguide.org/pain...painters-tape/
Let me know if it helps.
Old 03-13-2011, 05:39 PM   #4
Super Master Painter
Ole34's Avatar
how do you get good at cutting?? ...............you gotta want it !
Ole34 is offline   Reply With Quote
Old 03-13-2011, 05:41 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
You already got a major problem if the tape is pulling off the paint
Old 03-13-2011, 05:46 PM   #6
Gymschu's Avatar
Rewards Points: 184
Blue tape is for noobs, rookies, amateurs..........a good brush and some patience is WAAAAAAYYYYY better than using blue tape, and less time consuming. Plus you always have paint that bleeds underneath the tape and creates an even bigger mess.
Old 03-15-2011, 07:57 AM   #7
LOL, we're not talking about quitting smoking.
I think we're talking amongst ourselves here.
Old 03-20-2011, 08:51 PM   #8
Would it be possible to do this on textured walls? I just got done painting a room with textured walls, and it was less than fun... I had to used the blue tape, but I don't deny being a rookie. This is the first time I have painted textured walls.
JordanH is offline   Reply With Quote
Old 03-20-2011, 09:05 PM   #9
Rubbin walls since'79
Brushjockey's Avatar
Everyone thinks that painting is easy and anyone can do it.
You are seeing the skills that have been developed with practice and knowledge of how this stuff works.
Cutting in ( that's what it is called) is a learned art. Doing it on a textured wall is even harder.
If you end up hiring a pro, you now know a bit about what it is you would be paying for.
Good Luck!
Brushjockey is offline   Reply With Quote
Old 03-20-2011, 09:20 PM   #10
Believe me, I know that they are way better at it than I. Also, I'm sure it would have take a pro about a 1/5th of the time it took me. I just don't have the cash to pay for a pro right now, and I wanted to learn more about painting anyways. If I do a larger area like the living room, I plan on hiring a pro.
Old 03-20-2011, 09:31 PM   #11
Jordan- when people give it a shot and learn how hard it is, it makes for a better customer for us pros when the time comes. You know what it takes. Heck- I do my own plumbing!
Here's a little trick. If the ceiling is a texture other than popcorn type, run a bead of caulk around that edge and it will make a smoother corner than just a textured one, easier to draw a line on.
But caulking is another one of those things! Wet rag and a wet finger to smooth out.
The Following User Says Thank You to Brushjockey For This Useful Post:
jsheridan (03-21-2011)
Old 03-27-2011, 06:48 PM   #12
Drywall Texture Pro in Fl
stoner529's Avatar
Rewards Points: 154
what he said. with the exception that i think caulking is pretty easy to do!
I just lay a small line on and caulk with a dry finger, and a rag to wipe my finger off. don't apply to big a bead of caulk. you want maybe 1'/4 line
how to remove popcorn
stoner529 is offline   Reply With Quote
Old 03-27-2011, 07:16 PM   #13
General Contractor
SeattleSurfaces's Avatar
That bead of caulk in the corner will make your life way easier. It still takes a lot of practice to cut in and make it look nice, but with a heavy texture and no caulk, you could spend forever and never make it look pretty.
SeattleSurfaces is offline   Reply With Quote
Old 03-27-2011, 11:32 PM   #14
stoner529's Avatar
Rewards Points: 154
Oh very true. cutting in is a pain with paint. a steady hand is all you need and patience.
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Why do I hear my toilet draining in my ceiling and walls? yummy mummy Plumbing 5 12-27-2009 06:09 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Knockdown ceiling : My walls are orange peel.. Arkanoid Remodeling 4 08-07-2007 01:23 PM
