Ceiling Texture And Finish For Higher "appearing" Ceilings? - Painting - DIY Chatroom Home Improvement Forum
Old 12-30-2013, 03:52 PM   #1
Rewards Points: 209
Ceiling texture and finish for higher "appearing" ceilings?
Hi so I just removed my popcorn ceiling and I'm wondering what texture would make the ceiling look taller.
I have just an 8 ft tall ceiling. The living/kitchen/dining is all one room about 550 sq ft (it's just a condo)
Should I texture, orange peel or leave it flat?
What type of pain finish is best for making it look like more height? -flat, semi gloss, egg shell satin?
I want the illusion of higher ceilings
Also would crown molding help the space seem larger or taller?
The overall style of my room is a mix between modern mixed with rustic
crayola110 is offline   Reply With Quote
Old 12-30-2013, 05:46 PM   #2
Rewards Points: 12,804
Just leave it flat with no texture.
Ceilings need flat sheen paint or your going to be seeing every flaw.
Any trim such as crown is going to make the wall look shorter.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
crayola110 (12-30-2013), eandjsdad (12-31-2013)
Old 12-30-2013, 05:52 PM   #3
Jmayspaint's Avatar
Rewards Points: 534
I agree. Anything that draws the eye to the ceiling; molding, texture, sheen, are going to make the room look shorter.
Light colors, flat paint.
Jmayspaint is online now   Reply With Quote
Old 12-31-2013, 04:26 AM   #4
Rewards Points: 209
That sucks about molding, because I'm a fan of it and think it looks nice.
The ceilings are 8 feet tall.
I had read somewhere that reflective higher gloss paint can create depth in the ceiling, but I could also see how it would bring it attention.
I'll def try to go with something plain. Any other paint tips I could do?
How about paint in the kitchen, shouldn't that be semi-gloss or egg shell at least for cooking-oils and stuff?
Old 12-31-2013, 04:40 AM   #5
Rewards Points: 4,780
There is a newer trend in crown ceilings that to my eye makes my brain think the ceiling is taller. It appears like one big solid piece of trim, but it's an illusion. Described here:
http://inmyownstyle.com/2011/10/a-cl...emakeover.html
Some may feel the opposite though - that it brings the ceiling down.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
crayola110 (12-31-2013)
Old 12-31-2013, 04:41 AM   #6
I don't think you need eggshell in the kitchen on your ceiling. Haven't really heard of anyone cleaning their ceiling.
Old 12-31-2013, 01:36 PM   #7
Rewards Points: 209
Thanks jeff, like you said I think that big of trim can also make it look to brings ceilings down. It looks huge!
Old 12-31-2013, 01:53 PM   #8
It does look huge, but there's actually a gap there that is painted wall. So it's not huge like one big chunk of crown. To me it makes it look like the ceiling has been extended up 8", so the "hugeness" translates to "tallness" to my eye. If that whole thing were one big chunk of wood, it would have the opposite effect.
Old 12-31-2013, 02:00 PM   #9
Makes the wall look 6' tall to me.
Way to busy for a small room.
Old 12-31-2013, 02:05 PM   #10
Rewards Points: 209
Hmm I think the Crown molding might make it look taller while the really tall "chair" molding brings the room down again.
Wouldnt the walls appear Taller if you instead made the crown molding go a few inches deeper into the ceiling instead of deeper down the wall? Because in this instance they're taking away from the wall by making the crown molding look so thick
(i hope that description makes sense)
Wish there were more pics without that really tall chair molding
Adding Texture to Ceiling MLayden Drywall & Plaster 7 08-29-2012 04:20 PM
Need help with blending new texture ceiling catzcar Drywall & Plaster 9 04-11-2011 10:00 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
how to light sand texture ceiling mtom01 Painting 4 03-13-2010 01:11 AM
