Ceiling Primer/Paint Not Sticking - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 05:56 PM   #16
paper hanger and painter
chrisn's Avatar
Rewards Points: 122
[quote=DrHicks;811978]Only those who (obviously) have stock in SW or BM, and cannot handle the fact that millions of people choose a mid-grade paint, rather than an expensive top of the line paint.
Not everybody is willing to spend $65 per gallon for paint, nor should they.[/quote]
You will not get any argument from me
Old 01-04-2012, 07:28 PM   #17
Too Short? Cut it Again!
[quote=chrisn;812518]
Me neither. I nor my clients have ever spent that kind of money for paint.
Old 01-04-2012, 08:12 PM   #18
Not a Noob or Boob
If you don't understand why it costs $65 then you don't understand paint. And to suggest that BM paint costs $65 per gallon is just plain silly, and shows that you have never been to a JC Licht store. Super Spec out performs Behr for about the same price.
As far as their Aura line, paint one room in Behr and another in Aura. I would lay money that anyone's customers would prefer the fit and finish of Aura, plus the low VOC, over Behr any day. You can touch up with no flashing. It's a far superior paint.
I mean really, what are you saving by cheaping out on paint?
To the OP, your problem has to do with prep. 90% of painting is prep, prep, prep. After sanding and scraping you need to wipe it down. I wouldn't recommend water, it causes too much delay in the process and the benefit is negligible.
Take a broom and whisk as much dust and debris out of your field, and then, as stated, use a nice bonding primer, like Gardz.
The purpose of primer is to bond to the painting surface and give your paint something to grab. Therefore it is mostly made up of glues and binders, with a little pigment. Gardz is designed specifically for your application. There is also a product called Peel Stop, which works great for paint that is pealing and chalking. I use Gardz a lot and it has never let me down.
Good luck with your project! We've all been there.
Rob1975 is offline   Reply With Quote
Old 01-04-2012, 08:20 PM   #19
Rubbin walls since'79
Brushjockey's Avatar
I just applied the 65 dollar paint to one of my good clients open hall/stairs.
3 young girls, their friends, 2 springer spaniels, a cat. A dark green ( HC- 98). I am not worried about scuffing, or pigment rubbing off. takes a beating and keeps on ticking. Touches up when it gets needed.
No hesitation whatsoever to recommend and apply this paint in this situation. None. Worth every penny.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following 2 Users Say Thank You to Brushjockey For This Useful Post:
chrisn (01-05-2012), Rob1975 (01-04-2012)
Old 01-04-2012, 08:24 PM   #20
Not a Noob or Boob
I love being able to touch up and have it blend right in.
Old 01-05-2012, 04:30 AM   #21
chrisn's Avatar
Rewards Points: 122
[quote=sdsester;812634]
Well, now ,I will argue THAT point.All my clients spend good money on product,$65 every time? No. Do I spend $65 every time I buy paint for my home,no. Does a can of Behr ever show up on any of my job sites or in my home, NO.
The Following User Says Thank You to chrisn For This Useful Post:
Rob1975 (01-05-2012)
Old 01-05-2012, 03:23 PM   #22
I agree with most of the comments but a good thing to remember about paint is a surface should always be clean dull and dry and paint will stick if the surface is bare always prime with the right primer. In your case i believe the surface was wet to cause all the blistering that i see from that small pic.
shives is offline   Reply With Quote
Old 01-05-2012, 06:20 PM   #23
Hmm...I was about to post a thread on a topic about this when I came to here. If you want your paint to stay longer, use primer.
rochele20 is offline   Reply With Quote
Tags
blistering , olympic one , paint , primer
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 01:31 PM
Raise ceiling/Tray Ceiling. Is it even possible? Bombcru Building & Construction 10 02-08-2011 02:01 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
