Ceiling Primer/Paint Not Sticking - Painting - DIY Chatroom Home Improvement Forum
Old 11-12-2011, 03:01 PM   #1
Ceiling Primer/Paint not Sticking
Yesterday I scraped popcorn off my kitchen ceiling and then painted with Olympic One Primer/Paint. The ceiling had previously been painted before popcorn was applied. Today the paint is blistering up and coming off the ceiling in various places. I don't understand why this happened but more importantly, don't know how to fix it. Will I have to scrap the entire ceiling (or just what is loose) and then use sheetrock mud to patch the different levels or will another coat of paint cover it? What can I do to make the paint stick?
Shoals is offline   Reply With Quote
Old 11-12-2011, 04:29 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
I think this is a classic example of how the all in one paint is really BS. You needed a real primer that would penetrate the dusty surface that was left after scraping.
Also the degree that you removed the old tex makes a difference because the mud that texture is bound with is not a stong bonder- so it itself doesn't adhere to the previous paint well.
Your new coat created enough pull to rip it away from the paint.
That pic is pretty small- is it just in a few spots or all over?
Its hard to know how to advise you. but if there was a substantial amount of the tex mud left- a re-scrape and then prime with a good penetrating bonding primer ( Gardz, peel stop, Smart prime, all come to mind) will be needed.
You also coud do as you said, scrape the loose stuff THEN prime( I would prime whole ceiling)- then mud, spot pime mud- finish paint.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 11-12-2011, 04:59 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
As my esteemed colleague has said, scrape all loose and peeling areas, patch as needed, clean( get all the dust off) Prime with Gardz( or other bonding primer) , paint with paint from a real paint store.
Old 11-13-2011, 12:30 AM   #4
Did you use water to remove the popcorn? And, how long did you let it dry before painting?
Old 11-13-2011, 09:04 PM   #5
Too Short? Cut it Again!
There is and can never be such a thing as paint and primer in one!
Old 01-03-2012, 06:28 AM   #6
Me too
Don't use this Olympic primer/paint. Same thing w me! Im sanding sections & repainting w thinner layers. Gonna use Behr next time
Gili is offline   Reply With Quote
Old 01-03-2012, 06:36 AM   #7
Well at least we got discussions of absolute crap paint in one post! BEHRly paint at all should never be used but to paint the logo on the can. If you can get applied and to stick.
Old 01-03-2012, 08:11 AM   #8
A Little Of Everything
Rewards Points: 1,356
I guess I'll be the one who continues to point out that you're wrong.
If the surface is not wet or oily, and proper primer is used, Behr Ceiling Paint, or even Semi-Gloss (for the kitchen) will work fine. It's not the best paint on the market, but rather falls right in the middle or the price/quality spectrum, along with a whole host of other paints.
Please refer to the Sticky at the top of this sub-forum."This is a how to site, not a why I hate this product site."
DrHicks is offline   Reply With Quote
Old 01-03-2012, 08:16 AM   #9
Wear a cap have an umbrella handy with that watered down crap.
Old 01-03-2012, 11:44 AM   #10
I do exactly that before reading every one of your comments - and for obvious reasons.
Learn to paint, ya hack.
Old 01-03-2012, 05:22 PM   #11
DIY staff
Rewards Points: 7,174
Lighten up there Doc---no need to take this personally---Mike--(grumpy moderator)
Old 01-03-2012, 10:15 PM   #12
Okay, I'll not bother correcting horrible mis-information.
Old 01-04-2012, 04:58 AM   #13
chrisn's Avatar
Rewards Points: 120
Anothers OPINION is not necessairly mis-infornation.
You think Behr is fine, others don't ,it is just opinion
Who freekin cares in the long run?
Old 01-04-2012, 06:07 AM   #14
That's good advice to anyone who mentions Behr around here!
Old 01-04-2012, 07:28 AM   #15
Only those who (obviously) have stock in SW or BM, and cannot handle the fact that millions of people choose a mid-grade paint, rather than an expensive top of the line paint.
Not everybody is willing to spend $65 per gallon for paint, nor should they.
Tags
blistering , olympic one , paint , primer
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 01:31 PM
Raise ceiling/Tray Ceiling. Is it even possible? Bombcru Building & Construction 10 02-08-2011 02:01 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
