Old 08-18-2011, 02:25 PM   #1
Ceiling Paint - Water Leak?
Hi
I am brand new to this site so apologies if posted in wrong area etc,
I painted the ceiling in my front room today as there was a small leak upstairs approx six months ago ( I let the sink overrun ) and as you can see from the photo, there is still a stain showing in the ceiling.
Can anyone advise what paint or primer or anything that can be done to remove this?
I am a total newbie at DIY so any advice would be very much appreciated.
Hello from Dublin,Ireland also :-)
Ceiling Paint - Water Leak?-228806_10150752249870436_782170435_20417713_5029454_n.jpg
Smarten is offline   Reply With Quote
Old 08-18-2011, 04:00 PM   #2
m1951mm's Avatar
There is quite a bit of information regarding your problem already posted in different threads. Did you do a search using the words water stain or painting water damage?? If you do that you will see LOTS of info.
Now that said. I am not sure what products are available for you in Ireland. I prefer to use an oil based stain killing primer for water damage. I find that in using a latex stain killer the yellow can sometimes bleed thru again. I know here in the U.S. you can buy spray cans of Kilz (just make sure to protect everything from overspray from the can) or you can get just a quart of stain killing primer brush that on, once dry paint with your ceiling paint and you are good to go.
And Welcome to a really GREAT site for your home improvement needs. Lots of fun people here, let alone the great information.
m1951mm is offline   Reply With Quote
Old 08-18-2011, 05:17 PM   #3
paper hanger and painter
chrisn's Avatar
Kilz oil will work but this is the best
The Following 2 Users Say Thank You to chrisn For This Useful Post:
Gymschu (08-18-2011), m1951mm (08-18-2011)
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
newly painted ceiling paint cracking-Help! Basia Painting 1 01-22-2011 03:09 PM
Ceiling Paint White versus Wall Paint White David Riley Drywall & Plaster 1 01-13-2011 10:16 AM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Bubbling paint on ceiling caused by damp bathroom floor garv19 General Discussion 4 04-10-2010 08:38 AM
