Old 01-03-2013, 02:06 PM   #1
Ceiling Paint vs Regular Paint
Painting a ceiling. I had some left over interior white. So I went to Lowe's and asked "what's the diff", and the paint rep said "Ceiling paint is more porous, will let moisture through. If you paint a ceiling with regular interior, the moisture can't get through and you start getting cobwebs with little black balls in the corner of the ceilings".
Any truth to this? I always thought the only diff was ceiling paint was a flatter sheen.
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 01-03-2013, 02:16 PM   #2
Totaly wrong.
Your are right, it's just a flat finish.
Rule #1 never take any advice from a box store. If they knew what they were doing why are they work there for low pay?
Old 01-03-2013, 03:01 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
The difference between a ceiling paint and a flat wall paint is that the ceiling paint is supposed to be the flattest finish. No wash at all. The cobweb comment was kinda of off-
You can use a wall flat- but it will still have a bit of angular sheen. On some ceilings that can make a difference.
And a quality ceiling paint isn't cheap. if the cheapest thing they have is ceiling paint, count on it also being the worst product on the shelf.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 01-03-2013, 04:44 PM   #4
Gymschu's Avatar
Brushjockey, spot on as usual, although I might just disagree about the cheapest paint being ceiling paint and you shouldn't buy it........I love PPG's Ultra ceiling paint and I buy it at Menard's for about 17 dollars. It is dead flat and usually covers in one coat (flat on flat). I was having so much trouble with SW's Brilliance ceiling paint that I had to find something better.......thanks to ChrisN, I did.
The Following User Says Thank You to Gymschu For This Useful Post:
chrisn (01-03-2013)
Old 01-03-2013, 05:13 PM   #5
Mr. Paint's Avatar
It involves the pigment:resin ratio. Quality flat wall paints have more acrylic resin in them to promote wear, washability, etc. Paints designated as ceiling paints have less resin and more filler pigments that make them dead flat so you wont see lap marks on the ceiling. Lapping is more noticeable in critical-light rooms. (Think big or many windows)
Because of less resins, which add to the cost, your lower-line flats are able to be sold at less cost.
You can use wall paint up there, but you may be dealing with flashing andd lapping issues. If you must use it, thin it a little with water to help. Don't exceed the manufacturer's recommendation or you wil get rained on by paint splatter.
The Painter's Paint Store where QUALITY is ECONOMY
Mr. Paint is offline   Reply With Quote
The Following User Says Thank You to Mr. Paint For This Useful Post:
Will22 (01-04-2013)
Old 01-03-2013, 05:15 PM   #6
Haven't used it- maybe I'll give it a shot. My cheapest= worst is something that looks like a big northern animal...
The Following User Says Thank You to Brushjockey For This Useful Post:
Gymschu (01-04-2013)
Old 01-03-2013, 05:27 PM   #7
paper hanger and painter
chrisn's Avatar
Don't know about Menard's, never heard of them ,but at my PPG store , I get it for $18. It puts that Brilliance or whatever it is now, to shame.
The Following 2 Users Say Thank You to chrisn For This Useful Post:
Gymschu (01-04-2013), JamesRW (01-08-2013)
Old 01-03-2013, 05:32 PM   #8
Chris- Menards is a midwest box store chain. I prefer it to UknowWho
Old 01-03-2013, 07:51 PM   #9
That explanation by the Lowe's guy was pretty bizarre, pretty, pretty bizarre.
Old 01-03-2013, 07:56 PM   #10
LOL! I'm standing there thinking "but do I *want* moisture to go through my paint, into the sheetrock and maybe into the airspace of the next floor, I mean, isn't that a bad thing?"
Thanks to everyone who contributed! Sometimes I hold back on here thinking someone will rake me over the coals for a real dumb question. But usually the people here are really kind. It's appreciated from a fairly newbie DIYer.
Old 01-03-2013, 08:05 PM   #11
We mostly like to harass each other! It is to the entertainment (I hope!) of the original poster. To put one out and let the fun begin!
Old 01-03-2013, 08:07 PM   #12
Doug, moisture transfers through most all paints. Paints breathe. It's when they don't that you have problems. Higher sheens transfer less than low/no sheen.
The only people who get raked over the coals here are those ignorant DIY's who come here knowing nothing yet "knowing enough" to tell the pros here how it is and what works and doesn't. Also, those who need to be told something ten times in twenty different ways, and then insist that they're not getting any help. That's when it gets real fun here. Go ahead, make my day. Use ceiling paint, that's what its made for. Then you won't have any little black balls in your corners. The spiders are probably wondering what he meant by that.
The Following User Says Thank You to jsheridan For This Useful Post:
Will22 (01-04-2013)
Old 01-03-2013, 08:19 PM   #13
I've wondered about that sometimes. Some of them are pretty clueless, yet some of them are surprisingly knowledgeable. (Not the paint section so much, but other sections like plumbing especially have the occasional expert. Maybe they're retired or something?)
jeffnc is online now   Reply With Quote
Old 01-03-2013, 08:21 PM   #14
What is wrong with Brilliance, and how is it different from, say, SuperPaint Extra White?
Old 01-04-2013, 01:09 AM   #15
Matthewt1970's Avatar
Ceiling paint also has some anti-spatter/drip additives.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
behr ceiling paint? cals400ex Painting 14 11-21-2012 06:56 AM
Repainting Room With Peeling Paint: Advice Needed Magnetic Painting 8 10-15-2012 06:19 PM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
SW Brilliance Ceiling Paint - Seeing Roller marks bentleyvt Painting 50 03-22-2012 12:33 PM
Painted ceiling and all coats of paint underneath bubbled and peeled off! (Pictures) tunabreath Painting 0 09-12-2011 08:16 AM
