Ceiling Paint With Sand - Painting - DIY Chatroom Home Improvement Forum
Old 08-31-2009, 01:29 PM   #1
ceiling paint with sand
just put an addition on and was running into a problem with painting the ceiling. the old portions of ceiling were painted with paint that had a small amount of sand in it. not enough to show much texture but enough to be clearly different than the new drywall. what can i do?
jvollenw is offline   Reply With Quote
Old 09-01-2009, 08:33 AM   #2
Coatings Nerd
Check out a product from Zinsser called Roll-A-Tex. It comes in different textures, Coarse, Medium, and Fine. You add it right to whatever paint you are using. It's messy, so cover the floor well, and wear safety glasses so you dont get a shot in the eye , thats no fun.
NCpaint1 is offline   Reply With Quote
Old 09-01-2009, 01:53 PM   #3
NAV
or just put sand into your paint - use the sand they add to floor coatings for slip resistance and make sure you mix it frequently to avoid settling
NAV is offline   Reply With Quote
Old 09-02-2009, 10:29 AM   #4
Coatings Nerd
Dont do that, it's a mess, and too heavy for a ceiling. It will also be nearly impossible to roll out smoothly.
Got Dark Paint on Flat white popcorn ceiling DIYAmatureLeah Painting 6 01-22-2013 06:10 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
Ceiling paint problems, and color? mara Painting 6 08-02-2008 02:23 PM
