Ceiling Paint Repair - Painting - DIY Chatroom Home Improvement Forum
Old 08-09-2011, 12:56 PM   #1
Exclamation
Ceiling paint repair
Sprayed soda on ceiling and wiped off with damp cloth which removed texture (who knew?). I have tried multiple means and paints trying to match texture and paint to small, swiped area. I get the texture 'close enough' but can't get the paint to blend in. Finally I just paint the whole ceiling over and the area still doesn't blend in, stands out just as bad as ever. What gives?
Craig3 is offline   Reply With Quote
Old 08-09-2011, 05:20 PM   #2
It does look better the more the paint dries. Texture still not there and will have to think of another option for that. I even bought some texture paint at HD and the paint actually seemed to flatten out as it dried so that was money wasted. I also tried the spray can (never try that again) and tried some paint you mix with sand (better but still not it).
Old 08-09-2011, 05:22 PM   #3
pictures might help a lot for the guys that are familiar with texture. did you prime the retextured area before you repainted?
Old 08-09-2011, 06:30 PM   #4
Okay, pic attached. I am sure I primed in one of my earlier attempts. I think I have the paint matched now but still no luck on the texture. I suppose I will have to call a pro but I am in the country and for this small of a job I have a feeling they will want to do the entire ceiling (again) and it will cost way more than I would want to spend.
Old 08-09-2011, 06:52 PM   #5
you can buy spray texture, it comes in a spray paint type can. at the big box stores
Aphid is offline   Reply With Quote
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling Old&New Paint Issue tasmisr Painting 5 07-19-2011 10:19 AM
Ceiling Paint CeeZee Painting 12 09-22-2010 12:07 PM
Paint Bathroom Ceiling questions? Hypochondriac Painting 5 08-15-2010 04:51 AM
