Ceiling Paint Peeling When Tape Removed - Painting - DIY Chatroom Home Improvement Forum
Old 11-16-2011, 08:20 PM   #1
Ceiling paint peeling when tape removed
I painted my celing about 2 months ago. Yesterday I taped off the ceiling and painted my walls today. When i removed the tape from the ceiling, the ceiling paint peeled off under the tape. How do I fix this mess?
peggyb is offline   Reply With Quote
Old 11-16-2011, 08:35 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
What was the paint on the ceiling? had it been previously painted &/or primed? Common problem with no prime or paint with little adhesion.
How much got pulled off? if just a little and the ceiling was a flat- might just be able to paint it over and be good enough. Otherwise will take some taping compound, sand, prime, and repaint.
Also recommend trying to learn how to brush rather than use tape so much. This is just one reason why.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 11-17-2011, 08:38 PM   #3
celing paint peeling when tape removed
The original celing paint was oil based. I was advised that a latex paint with primer in it would be fine to use. Obviously that advice was given to me by someone who should not be working in the paint section!
I am removing the latex paint (it's peeling off in large pieces) and I will repaint.
Some bad advice has cost me time & frustration but I will chalk it up to a lesson learned.
What type of primer should I apply before I repaint with a late ceiling paint?
Old 11-17-2011, 10:03 PM   #4
im curious, was the paint and primer behr or valspar?
Old 11-18-2011, 05:47 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 622
Does it matter, neither one would have worked in this case.
To the OP, you need to get the latex off, prime with a quality bonding primer, then paint. This would entail a trip to a real paint store where you will get better advise.
Best option for Bathroom Ceiling Paint? tealab Painting 7 04-05-2013 04:49 PM
Removing peeling paint from the ceiling Nanna45 Painting 3 06-30-2010 03:42 AM
Pitted Ceiling Paint aumanpj Painting 13 01-11-2010 04:37 AM
Blue tape peeling away the old wall paint drlsubaru Painting 9 05-13-2009 09:58 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
