Ceiling Paint Peeling - Painting - DIY Chatroom Home Improvement Forum
Old 07-16-2008, 08:05 PM   #1
Ceiling Woes
Question
Ceiling paint peeling
My bedroom's ceiling paint is peeling. It also appears to be sagging a little. Is that water damage for sure? I'm at a lost at the moment.
oregon16 is offline   Reply With Quote
Old 07-16-2008, 08:38 PM   #2
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 852
It sounds like it could be water (hopefully not). Is there any yellowness in that area? Can you get a picture of the area in question?
Sir MixAlot is offline   Reply With Quote
Old 07-16-2008, 09:08 PM   #3
Ceiling Woes
Question
Old 07-16-2008, 09:09 PM   #4
Ceiling Woes
Thanks for looking at this, Sir MixAlot
Old 07-16-2008, 09:25 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
There's something real bad going on there
If your bed is underneath that, I'd move it away
You'll want to head up into the attic CAREFULLY and see what's up there
slickshift is offline   Reply With Quote
Old 07-16-2008, 10:00 PM   #6
Rewards Points: 852
There's definetly a moisture issue. Better take a look from the attic ASAP! Don't step on the drywall ceiling while your up there. How long has that been noticable?
Old 07-16-2008, 10:50 PM   #7
Ceiling Woes
I started noticing it a month ago and it got progressively worse. It's been dry out here, no rain. I wonder where the water is from.
Old 07-16-2008, 11:40 PM   #8
Rewards Points: 2,906
I agree with SirMixalot. What ever it is, it's important that you investigate and remedy the problem ASAP.
If you haven't gotten any rain lately, then I'd be concerned that the moisture seeping through your ceiling is urine from an animal who's built a home in your attic.
Also, you might want to go up into your attic with two pieces of two foot by four foot plywood to distribute your weight over 3 or more ceiling joist instead of just one or two.
And, also check the rafters along the roof line above that spot. It could be bats.
Nestor_Kelebay is offline   Reply With Quote
Old 07-17-2008, 12:03 AM   #9
Ceiling Woes
Found the problem. My heater/AC system (compressor outdoor) is in the attic and it is leaking water. The insulation is wet which explains everything. This is bad news.
Old 07-17-2008, 08:44 PM   #10
Rewards Points: 852
That's a bummer.
Just look on the bright side could be alot worse.
Old 07-17-2008, 09:33 PM   #11
slickshift's Avatar
The wet ceiling could have fallen on you while you were sleeping
Old 07-18-2008, 12:10 AM   #12
Ceiling Woes
Thanks folks. I appreciate all your advice. I'm now just waiting for the AC contractor to come figure out why the condensation unit is leaking. Probably something's clogged. I bought this old house and I really don't understand why would someone put the condensation unit in the attic. Though I'm not sure where else it can be placed.
Old 07-18-2008, 09:48 PM   #13
Rewards Points: 852
Here's job we did yesterday after a roof leak.
The ceiling fell down.
Re-insulated, drywalled and ready for texture.
Old 07-18-2008, 11:29 PM   #14
slickshift's Avatar
Nice pics
Old 07-18-2008, 11:53 PM   #15
Ahh. The joys of home ownership.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 07:07 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
Ceiling Paint CeeZee Painting 12 09-22-2010 01:07 PM
