Ceiling Paint Help - Painting - DIY Chatroom Home Improvement Forum
Old 10-12-2011, 10:26 AM   #1
self help
Ceiling paint help
Been checking out the site for awhile. Started to do some relatively cheap upgrades to our new house. I removed popcorn from the back half of the house and got it looking pretty good. Primed the walls and ceilings with Bullseye (not 1-2-3).
Everything looks good as far as the primer goes but I need some help with choosing paint for the ceiling. After reading and searching Im thinking about going with a the Promar 200-400, since its just in the office and play room no need for anything too fancy. Any special color used for ceilings? So many whites.
Second question I have for you guys is the cutting in? Obviously I'm pretty slow and concerned with the cut in portion looking different than the rolled ceiling. Cut in first, then roll? A wall at a time? Does it even matter?
Thanks in advance, Im sure more questions will come along.
bigjon is offline   Reply With Quote
Old 10-12-2011, 03:49 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 386
Cut first, roll second, one wall at a time unless you are using a true flat, then you can cut the whole room in. SW Brilliance is their new ceiling paint and it is pretty nice.
The Following User Says Thank You to chrisn For This Useful Post:
bigjon (10-12-2011)
Old 10-12-2011, 04:36 PM   #3
Too Short? Cut it Again!
Ceilings do not have to be white and to me they often look like box tops that are almost irrelevant to the room. Ceilings are painted white because we still think we are installing gas lamps with one fixture in the middle of the ceiling, where most of us need the light least. The white reflects the light.
Old 10-12-2011, 06:06 PM   #4
self help
I agree but in this particular room white is our choice. We do have plans for other ceiling colors in other rooms. I got some SW Brilliance tonight. I'll give it a go tomorrow.
Old 10-13-2011, 03:43 AM   #5
chrisn's Avatar
Rewards Points: 386
You will need 2 coats, even over a good primer
Old 10-19-2011, 10:09 AM   #6
self help
2 coats and the ceiling looks about as good as its gonna get. It ain't no level 5 but it will do for the back rooms. I used SW Brilliance. First coat I asked a little bit to much out of my roller. 2nd coat covered up good and brought out a nice bright white.
Now the yellow we picked needs to be toned down a bit. eeek
Old 10-19-2011, 04:57 PM   #7
chrisn's Avatar
Rewards Points: 386
Thanks for letting us know.
SW Brilliance Ceiling Paint - Seeing Roller marks bentleyvt Painting 50 03-22-2012 11:33 AM
Ceiling Paint White versus Wall Paint White David Riley Drywall & Plaster 1 01-13-2011 09:16 AM
peeled ceiling paint off, how to fix? philosophical Painting 3 10-19-2010 04:28 PM
Is ceiling paint special? SR996 Painting 2 03-27-2009 04:51 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
