Old 05-23-2012, 02:17 PM   #1
Ceiling paint cracking
We just had our ceilings redone and we went ahead and used ceiling paint. There are signs of the paint pulling away. Can I use primer paint to seal the ceiling over the ceiling paint?
project master is offline   Reply With Quote
Old 05-23-2012, 05:56 PM   #2
paper hanger and painter
chrisn's Avatar
no
Old 05-23-2012, 06:07 PM   #3
Mr. Paint's Avatar
Supply more information:
1. Is the paint peeling everywhere or mostly at taped seams and nailhead areas?
2. Are the back of the paint chilps chalky or dusty?
3. Is it peeling to a primer or to the drywall?
4. Was a primer used; which one?
5. What was the method of application?
6. How many square feet was covered and how many gallons did you use?
7. Which brand and series was applied?
Answers to these questions should help toward a resolution.
Mr. Paint is offline   Reply With Quote
Old 05-24-2012, 10:20 AM   #4
we removed the popcorn texture and had a nkockdown texture applied. We allowed the ceiling to dry before continuing. We have approximately 1500 sq.feet of ceiling and the only problem areas appeared in the living room sky light and spare bedroom. Not a large areas but will it get worse. We had our contractor look at the problem areas and he indictaed the chips are chalky. They are not at seams or nail heads We did not apply a primer first but used a ceiling paint that we bought from Lowes. I want to ease my mind, and therefore pose the question will applying a primer over the ceiling paint resolve the issue. The ceiling paint is latex based. looking forward to any suggestion that will help.
Thank you
Project Master
Old 05-24-2012, 11:13 AM   #5
Mr. Paint's Avatar
After the removal of popcorn, a primer is generally used. Scrape off anything loose and prime with a fast-dry oil-based primer, such as Zinsser Cover Stain. Priming over the existing, sound ceiling paint is useless.
If the surface areas that have peeled are chalky (Perhaps a soft 'Easy-Sand' joint compound was used) a better primer to use is Zinsser Gardz.
The Following User Says Thank You to Mr. Paint For This Useful Post:
Gymschu (05-24-2012)
Old 05-25-2012, 04:47 PM   #6
thanks ...just to be clear ab oil based primer first then the ceiling paint, which is latex.
Project master
SW Brilliance Ceiling Paint - Seeing Roller marks bentleyvt Painting 50 03-22-2012 12:33 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Painted ceiling and all coats of paint underneath bubbled and peeled off! (Pictures) tunabreath Painting 0 09-12-2011 08:16 AM
Ceiling Old&New Paint Issue tasmisr Painting 5 07-19-2011 11:19 AM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
