Ceiling Paint Bubbles - Painting - DIY Chatroom Home Improvement Forum
Old 01-04-2017, 08:33 PM   #1
Rewards Points: 6
Ceiling Paint bubbles
We recently scraped popcorn off of our living room ceiling to go to a flat finish. After scraping there was a lot of old peeling paint leftover, we patched some but ended up using a triple thick water-based primer (Zinsser Peel Stop). While drying some bubbles appeared but disappeared the next day. We painted over the primer with a latex-based flat ceiling paint and now have bubbles all over that don't seem to be going away (one area was painted over a month ago). We washed down the ceiling and let it dry for a couple of days before painting so it's not due to moisture or dust.
Anybody have ideas on what went wrong and how we might fix the problem?
HeightsHouse is offline   Reply With Quote
Old 01-04-2017, 09:51 PM   #2
Rewards Points: 1,355
Re: Ceiling Paint bubbles
The naked, torn up drywall paper will do that when it gets wet. You should have sealed it with something like RX 35.
mathmonger is offline   Reply With Quote
Old 01-04-2017, 10:23 PM   #3
Rewards Points: 6
I'm fairly sure we didn't scrape down all the way to the dry wall but regardless what solutions might you recommend given the current state of things?
Old 01-05-2017, 07:31 AM   #4
Gymschu's Avatar
Rewards Points: 832
Scrape off the bubbles, fill the craters with spackle or joint compound, at least 2 coats, allow that all to dry, sand, prime, paint.
Giving us your general location helps us better help you!
Old 01-05-2017, 08:01 AM   #5
Rewards Points: 6
I figured something like that, I was preparing myself to sand the entire ceiling down to drywall but your idea seems a bit less grueling.
Doing a google search on this issue gives some pretty interesting solutions, one of which was using an iron to flatten the bubbles. Made for a great picture of my girlfriend ironing the ceiling but didn't do a thing.
Old 01-05-2017, 11:39 AM   #6
Anonymous Tard
getrex's Avatar
Rewards Points: 16
Gards is good for torn paper but regardless, what gymschu said is the standard procedure.
getrex is online now   Reply With Quote
Old 01-05-2017, 12:42 PM   #7
Rewards Points: 6
I assume applying Gardz over the paint is not an option?
Old 01-05-2017, 05:14 PM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 392
Certainly is an option , especially if it was cheap ceiling paint. I would just try a small area and see what happens
Old 01-06-2017, 06:26 AM   #9
Anonymous Tard
getrex's Avatar
Rewards Points: 16
Next time scrape it down to the drywall. Better results that way.
Problem with bubbles in oil base paint ezemyr1 Painting 7 10-17-2016 05:38 AM
Paint Bubbles Moxified Painting 4 04-12-2013 07:06 AM
New ceiling paint separation Nonyab Painting 15 04-01-2013 04:38 PM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
