-   -   ceiling paint in bathroom (http://www.diychatroom.com/f4/ceiling-paint-bathroom-4368/)
gorilla325 10-16-2006 09:51 PM
hi, everyone, i have a problem with the ceiling paint in my bathroom. i did some searches in the forum, trying to find a solution for my question, but i could not find it. so here it is.
i used bear paint from homedepot to paint my bathroom ceiling. it's a ceiling paint,interior flat from behr premium. my first shower after the painting, there appeared to be waters forming on my ceilings. the water then formed raindrops-like shape and dropped down from the ceiling... after a while, the spots where "raindrop" formed were visible!:( i don't know what to do... should i repaint? my bathroom after shower were quite humid. it's an old house, so the space is quite tight. i have a window, but opening it did not solve the problem.
i understand that people here are professional and think behr are inferior. but my bathroom was painted about 3~4 years ago with behr paint too, and the paint fixed the mildew problem that time, with kil primer. however, i can't recall we used ceiling paint 3~4 years ago, or just normal wall paint.
dougrus 10-16-2006 10:12 PM
Hi welcome to the forum....
I have a few questions that will help the other members and myself try to find the problem.
1. I assume you have no exhast fan? This is very important in keeping moisture at bay in a bathroom.
2. How long did you wait after you painted the ceiling before you used the shower?
3. What was the surface of the ceiling like before you painted it? Did you prep the ceiling by lightly sanding and cleaning before painting?
747 10-16-2006 11:26 PM
first you went with the wrong paint. Always go with zineers permawhite mold and mildew resistant for bathrooms. When i did my bathroom i went with zineers (spelling i think) bulls eye 123 primer and the perma white for the paint. I listen to the painters here like slickshift.
Paintguy26 10-17-2006 06:10 AM
1) Come here, before you paint
2) Shop for paint at Sherwin Williams or a Benjamin Moore dealer.
3) You'll be suprised that you can buy MUCH better paint, for about 5-10 more per gallon, while saving you this exact trouble your having.
4) I recommend listening to painting contractors in here. Most of us are reliable and consistant.
Now...your problem. I'll tell you how to fix it, not explain why it failed.
*You need to go with a bathroom/mildew/moisture paint. Perma White(zinsser) or Bath Paint(sherwin) are ideal. You also need a good primer/sealer. (Zinsser) 1.2.3 is the primer I use daily. Sand your ceiling and wipe it. Paint 1 coat with the primer. (Follow dry times) Paint with 1 coat of 'bathroom paint'. It's your choice to put 1 more coat. Ideally, (as the paint can probably says) it could take a week or more for the paint to really dry and 'cure', before getting moist/being cleaned/etc.
Now, we all know, not everyone has a spare bathroom to shower in, but if you do....use it for at least a few days. If not, try to paint as far ahead of a shower as you can. Tell the members of the household to plan on not showering there for a day or so. :wink: (they/you might go to a friends house, etc)...Using this paint/method should guard you against any further problems. I've done it just like this, it works, but only if done the way I've described.
Good luck
dougrus 10-17-2006 07:02 AM
Do not forget that a very important aspect of this is that you have no exhast fan and the room is very small. Over time the excessive moisture WILL do damage. I think one of your priorities should be to install one. A window is often not enough because the steam rises right to the ceiling. The right paint and techniques as described above will help...But I think it is important to address the excessive moisture.
SgtBaldy 10-17-2006 11:05 AM
Only thing i would add is if there are existing water stains on the ceiling then go with zinnser cover-stain oil primer. Water stains will come through water-based sealer like 1-2-3.
gorilla325 10-17-2006 11:25 AM
hi, thanks for all the replies.
1. no, i do not have an exhaust fan.
2. i waited for 2 days i think. or 1 and half days before we started to use the bathroom.
3. the condition of the ceiling was fine. i mean there's no flakes, no mildew. i did not sand and clean the ceiling before i prime and paint. well, now come to think of it, i might see some dust. however, i thought i should get flakes, not the "raindrop".
the paint looks fine for now. the problem is the the moisture formed raindrops on the ceilings. it seemed to me that many of you suggested me to repaint the bathroom with better product. i am really puzzled why i used behr before and was fine, but now i have this "raindrop" problem... :eek: i will need to find some paintshot, i guess.
can i get a dehumidifier so the paint could dry off more quickly? just wondering...:p
Paintguy26 10-17-2006 05:10 PM
Raindrops are normal...it's just excess moisture that puddles up. It has nothing to do with what product you used. BUT...a better product will help guard against these 'raindrops' from infiltrating underneath. Good luck
ps-just use a fan to dry the paint faster...or turn up the heat for a bit
gorilla325 10-17-2006 08:55 PM
thanks. :)
at least i know now i need to find a way to get rid the moisture, not repaint...
Paintguy26 10-18-2006 06:06 AM
Originally Posted by gorilla325 (Post 21125)
thanks. :)
Ok, I think you're missing something here. I'll be blunt....
I would repaint with a Bathroom paint, following the steps marked out. :yes:
Then you can have peace of mind....
...and I would either put a fan in the window during showers or look into something to cut down on the moisture buildup...
J187 10-18-2006 03:13 PM
Seriously, Gorilla, what I think you are not realizing that Paintguy is trying to point out is this.
Lets say your post didn't say anything about raindrops, moisture or anything. IN fact, pretend you posted "hey guys, I just painted my ceiling w/ behr paint". You'd get the same response from us. The point is, these guys are trying to save you the hassle of having paint penetrate the surface of the garbage behr paint you used and begin destroying the walls. It will moisten and soften the compound or plaster. Walls will loosen, paint will flake, it'll become a hell of a lot more work. DO yourself a huge favor. Go to Sherwin, buy bathpaint. Last time I was there, bathpaint was on sale - I bought a quart for $9.59. I don't think you can even buy behr for that. <~~ Look, I have such little respect for behr, I won't even capitalize the b. :)
Seriously though, Behr WILL break down and allow moisture into your walls. ESPECIALLY without an exhaust fan. LIsten, your house will LOVE you if you just take a little time effort and money and do this right. Repaint w/ bathpaint. A little trick to use, while you are giving the paint ample time to dry if you only have one bath, avoid using the shower at all for at least one or two days, then, switch to quick baths if you have a tub for the next few days. It won't keep all the moisture out, but it will stop the water from splashing to the ceiling and it will reduce the amount of moisture by alot. Also, its not a very expensive nor a difficult job to add an exhaust fan. It may require a bit of wiring if you wish to put it on a different switch then your other lights, but its worth whatever you have to do, even if that means paying someone. You can install a nice countdown timer on the fan too, that way you can set it for 45 minutes, take a nice 15 min shower and get out knowing the fan will clear moisture a full half hour after you are done. Good luck.
gorilla325 10-18-2006 06:10 PM
thanks, guys. you guys are very serious about this behr paint thing. :eek:
kk, i am going to look for a paint shot around my house. see if i could put my hands on the paint brands, you guys mentioned.
exhaust fan...it seemed to me that you need to open up the wall and do stuff...that scares to me... i doubt i could do the job.
one more thing, if the ceiling is not very straight,, could this be one of the reason the waterdrops formed? i do not mean a rough surface, however, some parts of my ceilings looked wavy... the surface looked smooth enough though.
JMGP 10-18-2006 06:38 PM
Gorilla...
I agree with what all has said above...
Just want to add another thought as to "why" you see more than usual moisture....
When new paint is applied it goes through a curing process... all of the VOC's start to evaperate... which causes moisture (humidity)... have you ever painted a room and the windows fog up on you? That is from the curing process....
If you used a semi gloss... that would take longer to cure than a flat paint... and if you took a shower a day later... the paint was probably still releasing it's VOC's... It may have been dry to the touch but still curing....
Also... if it is colder outside where you live it is probably colder inside... so when you take a hot shower is causes MORE moisture in the air...
Your issue is nothing to be alarmed about... it is just a couple of combined factors that are creating access moisture... when or if you re-paint it I would put a fan in the room to circulate the air to allow the paint to cure faster...
And like some have said... stay away from the orange store for your paint... use a "paint store" for your painting needs... I recommend Ben Moore...
dougrus 10-18-2006 08:07 PM
Gorilla,
In a situation like this where there are factors working against you, i.e the size of the room, lack of fan, below average paint, you need to use whatever means you can to ensure that damage to paint walls, etc is mimimized as much as possible. You cant enlarge the room, the fan seems to be something you dont feel you can do or dont want to hire out, so, by default, you need to use the best possible paint that you can to seal out the water.
Example: my sister just spent like 15,000 on a bathroom last year....they didnt have a fan either....About a month ago she called me over to look at her new popcorn ceiling above the shower...spots of black mildew everywhere.
Dont mean to sound dramatic but moisture is insidious...if you give it any way to get into your houses structure it will do damage.
Point is, if you are seing even a little damage to the paint now, give it a few years of daily showers, etc... As the guys said, save yourself the time and effort now and prime and paint with a product designed specifically for this application.
Just my 2c
:yes:
ohman 09-10-2012 05:42 PM
Sorry to "wake" this thread. Here is a photo of our stand-up shower room and the ceiling mildew:
http://s17.postimage.org/s9g5ex99n/m...th_ceiling.jpg
A contractor friend of ours suggest that we use a product called "marlite" for the bathroom ceiling, said that it would prevent any mildew problems like this in the future. Can anyone please comment on this please? Thanks!
