Old 08-05-2010, 03:47 PM   #1
Question
ceiling paint
I painted my bathroom gray with white ceiling. Even though I used painters tape I did not get a straight even line where the wall and ceiling meet. I have to stand on a ladder to reach and it is to awkward to use a good angled brush. Any suggestions on how I can even this out without repainting?
saderjoe50 is offline   Reply With Quote
Old 08-06-2010, 12:03 AM   #2
ceiling paint
If you are skilled with a caulking gun you can run a small bead of white caulking where the two substrates meet. Admittedly it is tricky to do for DIYers (and many pros), but when done correctly it gives a very sharp line.
Windows is offline   Reply With Quote
Old 08-06-2010, 02:18 PM   #3
Handyman
ceiling paint
Yep, I'm with Windows. Be sure to cut a VERY small hole from the caulk tube though. You just want a thin bead...just wide enough to get the seal breaker (on the caulk gun) into and cut it on a diagonal.
Incidentally, the same procedure works great for the top of the baseboards too. Nice clean look.
canadaclub is offline   Reply With Quote
Old 08-07-2010, 09:25 AM   #4
Matthewt1970's Avatar
ceiling paint
The caulk will still need to be painted.
Bathroom ceiling paint is peeling not-real-handy Painting 5 06-04-2010 08:53 AM
Self-priming ceiling paint? slickracer Painting 4 11-19-2009 07:01 PM
Ceiling hairline Cracks and New Paint sw8689 General Discussion 9 11-11-2009 12:43 PM
Is ceiling paint special? SR996 Painting 2 03-27-2009 05:51 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
