-   -   ceiling paint (http://www.diychatroom.com/f4/ceiling-paint-78005/)
saderjoe50 08-05-2010 03:47 PM
ceiling paint
I painted my bathroom gray with white ceiling. Even though I used painters tape I did not get a straight even line where the wall and ceiling meet. I have to stand on a ladder to reach and it is to awkward to use a good angled brush. Any suggestions on how I can even this out without repainting?
Windows 08-06-2010 12:03 AM
If you are skilled with a caulking gun you can run a small bead of white caulking where the two substrates meet. Admittedly it is tricky to do for DIYers (and many pros), but when done correctly it gives a very sharp line.
canadaclub 08-06-2010 02:18 PM
Yep, I'm with Windows. Be sure to cut a VERY small hole from the caulk tube though. You just want a thin bead...just wide enough to get the seal breaker (on the caulk gun) into and cut it on a diagonal.
Incidentally, the same procedure works great for the top of the baseboards too. Nice clean look.
Matthewt1970 08-07-2010 09:25 AM
The caulk will still need to be painted.
