Ceiling Paint - Painting - DIY Chatroom Home Improvement Forum
Old 01-25-2009, 09:04 PM   #1
Rewards Points: 14
Ceiling paint
I will be painting an old celetex ceiling in my daughters bedroom.It has small grooves where it is put together.The paint cracks over time in these joints.Is there a ceiling paint with some elasticity to it? Thanks for any help.
Glenn Archer
G Archer is offline   Reply With Quote
Old 01-26-2009, 02:12 AM   #2
Rewards Points: 2,906
Not a ceiling paint per se, but there is something called an "elastomeric coating". I have never used an elastomeric coating, so I really don't know if it would be appropriate for your application.
Basically, an elastomeric coating is intended for masonary (usually) buildings which have cracks in them which open and close with the seasons (often due to frost heave). The coating will span across the joint and will stretch as it wides and contract again as it closes. It's kinda like that plastic that the toy "Stretch Armstrong" is made of; it stretches completely out of shape, but always reverts to it's original shape once the forces on it are released.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 01-26-2009, 09:08 AM   #3
A good quality latex paint will have good elasticity. Most of the new quality latex paints are almost like plastic. I don't mean the paint you buy for $20 a gallon at HD.
Josh Jaros
jaros bros. is offline   Reply With Quote
Old 01-26-2009, 10:07 AM   #4
Rewards Points: 506
Could you supply a pic? If these are just seams between panels, I think they should be caulked with elastomeric paintable caulk (I use DynaFlex 230) and then topcoated with the mid-grade paint of your choice.
SirWired
sirwired is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
