02-14-2008, 02:02 PM
#1
Ceiling Paint
What is the difference between ceiling paint and regular latex wall paints?
02-14-2008, 05:35 PM
#2
Handyman
Ceiling Paint
Cost is one issue. Also, latex wall paints are available in different sheens..eggshell, satin, etc. Personally, if all you need is a flat white, I always use drywall primer. It's flat, covers well and is less expensive.
02-14-2008, 06:46 PM
#3
Ceiling Paint
Ceiling paint is formulated merely to cover/hide the old coating and not impart any sheen (generally speaking). Wall paints have to stand up to stains and burnishing, people bumping into them, fingerprints and need to have greater durability. That is why there is such a big difference in price. While a primer may work, I wouldn't recommend it and ceiling paints are pretty cheap anyway. You may spend more time than you need to because primers are built to seal, but not necessarily to hide. Of course, that's just my opinion.
02-14-2008, 07:45 PM
#4
Tired, Cold, and Damp
Ceiling Paint
Wall paints are formulated to be on walls, where they need to be more washable, dirt repellent and burnish-resistant (among other things)
With ceiling paint, many of those things aren't necessary, but things like being higher hiding, having less splatter while applying, and having higher adhesive qualities are more important
02-14-2008, 08:09 PM
#5
Handyman
Ceiling Paint
I have always been interested in trying the ceiling paint which goes on pink or blue and then turns white but, and I'll be honest with ya's...its like showing up at a new customer's house with all brand new tools, brand new pouch and brand new truck! Sort of lacks the 'craftsman' image. The reality is sometimes I find myself painting in some difficult lighting situations where that type of paint would come in handy.
02-14-2008, 09:49 PM
#6
Ceiling Paint
To be honest, I haven't tried it
But I would be remiss not to mention that I have not heard or seen anything good whatsoever about the actual application or finish with that type of paint
Only bad reviews of application and finish problems
Not first hand information I know, and I don't usually pass along hearsay (and won't w/o saying it is hearsay)
But when your dealing with paint on a professional level, and so many DIYers on sites like this, it's a little disconcerting to hear so many overwhelmingly negative reviews
I suppose what makes the paint work as a gimmick, means the actual paint product suffers
02-15-2008, 07:35 AM
#7
paper hanger and painter
Ceiling Paint
There you go, I have tried it (once) the idea was good but the quality not so good. If I remember it took 3 coats to cover on an already white ceiling, hardly worth watching the pink turn white, although the homeowner was intrigued, at least the first time around.
02-15-2008, 12:13 PM
#8
Ceiling Paint
ceiling paint is amazing, I'm applying some Behr now and its a lot "stickier" wont drip and goes on so easily. I have heard the ones that apply pink are good too, but I just went with the Behr and the color is a lot nicer than the primer I applied first.
02-15-2008, 01:23 PM
#9
Chicagos Green Contractor
Ceiling Paint
It is more than just cost, they are formulated to "stick" to the wall very differently. Ceiling paint is formulated not to drip and covers differently with the change in the formula, so that gravity doesnt get the best of the paint.
02-16-2008, 12:25 AM
#10
Ceiling Paint
Lame question here - So why not use it on walls too?
02-16-2008, 12:34 AM
#11
Ceiling Paint
usually most people want a different sheen on the walls like eggshell, semi-gloss for trim and flat for ceiling paint
02-16-2008, 12:35 AM
#12
Professional Handyman
Ceiling Paint
An old painter's trick from years back was to add a few drops of blue colorant to each gallon of ceiling paint. The addition of blue made the white paint appear even whiter and crisper to the human eye.
02-16-2008, 06:17 AM
#13
Ceiling Paint
Because it is not formulated to repel dirt and dust (as being upside-down gravity does that), is not washable by any means (again no need for that on ceiling), and has horrible wearability (again, not needed on a ceiling)
Technically you could, but you don't want to
(just because you can doesn't mean it's a good idea)
It will be looking pretty poor in short order
02-26-2008, 09:24 PM
#14
Ceiling Paint
We used the ceiling paint that goes on pink and drys white. That stuff is the best! Its so easy to tell where you've painted and where you havent. We've done all the ceilings in our house with it. Try it, you'll like it! We used the Glidden paint.
02-29-2008, 02:54 PM
#15
Penniless Parent/HO
Ceiling Paint
Hi All, Regarding the price of ceiling paint, what is the standard price in relation to wall paint? The same? Half as much? More that primer? Less than primer? Also, is there a ceiling primer different from what we would use for walls?
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
