Old 03-30-2011, 01:35 PM   #1
ceiling paint
whats the best ceiling paint to use to avoid marks/streaks/and roller marks
dholtz is offline   Reply With Quote
Old 03-30-2011, 01:46 PM   #2
Experienced
Jackofall1's Avatar
ceiling paint
Hello and welcome dholtz to the best DIY'r site on the web.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
dholtz (03-30-2011)
Old 03-30-2011, 03:29 PM   #3
ceiling paint
Hello Dholtz, welcome to the site!
Well there's really no easy answer to your question, if there was an absolute best there wouldn't be as many differences between them all. As you will notice here and on any forum everyone is entitled to their opinion and will let you know what they feel is best.
Ive painted for quite awhile now and Ive worked with a number of different products, so why don't you tell us what you have used in the past and why you did or did not like it. This way we can try and find something you'll have good results with.
HDwetPaint is offline   Reply With Quote
The Following User Says Thank You to HDwetPaint For This Useful Post:
dholtz (03-31-2011)
Old 03-30-2011, 04:13 PM   #4
Painting Company, NY
housepaintingny's Avatar
ceiling paint
As the previous poster said, we all have preferences. I personally like Sherwin Williams Promar 200 flat for ceilings, it actually seems better than some actual ceiling paints I have used. To avoid marks when painting the ceiling use a quality 1/2 inch roller sleeve. Maintain a wet edge and overlap your rolling. If a second coat is needed then roll the ceiling in the opposite direction of the first coat.
housepaintingny is offline   Reply With Quote
The Following User Says Thank You to housepaintingny For This Useful Post:
dholtz (03-31-2011)
Old 03-30-2011, 04:30 PM   #5
ceiling paint
I'v had good luck with glidden high hiding white flat. and like housepaintingny said use a long roller and dont roll the roller dry.
The Following User Says Thank You to DannyT For This Useful Post:
dholtz (03-31-2011)
Ceiling Paint White versus Wall Paint White David Riley Drywall & Plaster 1 01-13-2011 10:16 AM
peeled ceiling paint off, how to fix? philosophical Painting 3 10-19-2010 05:28 PM
Ceiling hairline Cracks and New Paint sw8689 General Discussion 9 11-11-2009 12:43 PM
Is ceiling paint special? SR996 Painting 2 03-27-2009 05:51 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
