Ceiling Fix - Painting - DIY Chatroom Home Improvement Forum
Old 11-24-2013, 12:43 PM   #1
ceiling fix
I have inherited a ceiling in the living room that someone tried to spray a popcorn type of texture on. Some place have big blobs of it. As if that wasn't bad enough they then painted it with glossy paint. I've started scraping it off and sanding the surface. I was then going to prime the ceiling and paint with a flat paint. Is this the proper approach? Any ideas on how I can fix this mess would be greatly appreciated.
Thanks in advance
swhite is offline   Reply With Quote
Old 11-24-2013, 01:03 PM   #2
Rewards Points: 12,812
That's about it. Might try missing it down with water to see if it will loosen up.
You could also try and rent a drywall sander.
It should be a 10 powered disk with built in dust collection.
http://www.coastaltool.com/a/port/78...all_sander.htm
swhite (11-24-2013)
Old 11-24-2013, 05:10 PM   #3
Rewards Points: 5,974
Once you scrap some so the water will have a chance to get in it should help some. But be aware you will probably need to skim coat it when done.
The Following User Says Thank You to ToolSeeker For This Useful Post:
swhite (11-24-2013)
Old 11-24-2013, 10:01 PM   #4
Thank you for the advise. I really appreciate it.
Ceiling Joist Size russ_mc Building & Construction 7 02-24-2012 05:06 PM
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 10:27 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
