Ceiling Corner Painting - Painting - DIY Chatroom Home Improvement Forum
Old 06-04-2007, 09:50 PM   #1
Ceiling corner painting
Is there a reliable way to paint the tops of walls withtout getting paint on the ceiling? I have seen those small pads at Hopme Depot with the wheels on one side. Do they actually work as they are advertised?
Edging in takes way to long to do and is frustrating when making a mistake.
What about painting in a 3 way corner?
williamp is offline   Reply With Quote
Old 06-04-2007, 10:03 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
The most reliable way is with quality materials and tools, and a steady hand
Well, I'm not sure how they are advertised
I have not used them, but my DIY girls have and they say if used with care, and not dipped in too much paint, they can work OK
Apparently if you get too much paint on them, you quickly get nice, straight, line of wall paint on the ceiling from the (now) wet wheels
Again, by hand with quality products
slickshift is offline   Reply With Quote
Old 06-05-2007, 10:43 AM   #3
On painting the 3 way corners, are there any brand names of materials that are recommended for doing a good job?
Old 06-05-2007, 07:28 PM   #4
Eibwen
I cheat and use a two foot painters straight edge and some rags.. Try not to take a loaded brush directly up to the edge. Get somewhat close and finish with a drier brush to feather. Wipe the straight edge often with disposable painters rags or paper towels. Works good on chair rails too.
Sammy is offline   Reply With Quote
Old 06-06-2007, 08:28 AM   #5
RippySkippy's Avatar
a steady hand and a good quality chisel brush (purdy for example)...I've not found any "gadget" that gives the results I like...and I HATE to paint.
RippySkippy is offline   Reply With Quote
Old 06-07-2007, 02:40 AM   #6
Pro Painter
It takes some practice to use a sash brush, but you'll get the hang of it.
Best if you have some of the ceiling paint around to touch it up.
joewho is offline   Reply With Quote
Old 06-08-2007, 09:28 PM   #7
Workaholic's Avatar
Yes I agree with Joe, Get yourself a sash brush or otherwise known as an angle tool, steady your hand and practice. An angle tool is a great beginers tool. I would recomend getting a 3".
Workaholic is offline   Reply With Quote
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Painting kitchen ceiling making me crazy! Kay Gremban Painting 5 06-15-2007 02:03 AM
Painting walls different color at an outside corner J187 Painting 8 08-16-2006 08:16 PM
Painting textured ceiling Unregistered Painting 5 06-17-2005 02:27 PM
