Ceiling Color Or Wall Color - Sloped Portion Above Stairs - Painting - DIY Chatroom Home Improvement Forum
View Poll Results: What color should sloped/angled portion be painted?
Wall color 0 0%
Ceiling color 4 100.00%
Voters: 4. This poll is closed
Old 04-24-2012, 11:07 PM   #1
Ceiling color or wall color - sloped portion above stairs
Paining my hall way (upstairs and down). Should the short (3-ft) angle above the first few stairs be wall color or ceiling color?
It's the portion under the closet in the room above stairs.
I'm leaning towards ceiling color but wondering what the consensus says.
BostonBurb is offline   Reply With Quote
Old 04-25-2012, 05:12 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 224
50-50, take you're pick, personally it would be the wall color for me
Old 04-25-2012, 07:10 AM   #3
What two sections are adjacent? If one is a ceiling, it should be ceiling. Technically, a horizontal or angled surface overhead is a ceiling.
Old 04-25-2012, 04:49 PM   #4
chrisn's Avatar
Rewards Points: 224
[quote=jsheridan;907041]What two sections are adjacent? If one is a ceiling, it should be ceiling. Technically, a horizontal or angled surface overhead is a ceiling.[/quote]
Really? I did not know that. I have seen it both ways about 50,50.
Old 04-28-2012, 05:45 PM   #5
It is/was primed. I had my wall paint out so I cut it in with the wall color which is fairly light (BM Lacy Pearl). The problem I have is that the sloped portion is the same texture as the wall, not the ceiling.
It's a small piece so I can always change it afterwards if necessary.
Does seeing a pic make the choice any more obvious?
Thanks again!
Old 04-28-2012, 06:03 PM   #6
chrisn's Avatar
Rewards Points: 224
Well, if it has no texture and the ceiling does, that makes it pretty easy to me.
Old 04-28-2012, 06:03 PM   #7
Rubbin walls since'79
Brushjockey's Avatar
I vote ceiling- fer shure!
Oh- texture.... well not so fer shere- could go either way. but the text does throw it to wall a bit- if the wall color is dark I might lean more ceiling...
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 04-28-2012, 07:36 PM   #8
ltd
Rewards Points: 536
i'm going to say mmm wall,no no i mean ceiling. ok for real , i don't think the texture on the ceiling is original to the house and think the texture should have been continued to that angled part. soooo with that said i'm going to say ceiling final answer, p/s that strip of moulding on your ceiling i would paint it and make it disappear, hey i could be wrong and the pictures do help but its still not like being up close and personal
ltd is offline   Reply With Quote
Old 04-30-2012, 07:44 AM   #9
The sloped area over my stairs is painted ceiling color.
canoes is offline   Reply With Quote
Tags
ceiling , color , sloped
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 10:27 PM
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 01:10 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
