Ceiling Color? - Painting - DIY Chatroom Home Improvement Forum
Old 01-11-2013, 08:58 PM   #1
Ceiling color?
What do you think about SW bright white for ceiling paint color?
I started using SW Eminence flat stock ceiling paint. I Switched to Promar 200, and it was tinted to Extra White to match the Eminence stock color. After painting and seeing a side by side, its clear the tinted Promar is much bluer. I still have 80% of the ceilings to paint, considering a color tint switch.
Adrenalinejunky is offline   Reply With Quote
Old 01-11-2013, 09:15 PM   #2
Rewards Points: 13,300
A bright white will show every flaw in the ceiling. Need to stick with flat.
Old 01-11-2013, 09:24 PM   #3
Flat as stock white? Ive also heard good things about Sw snowbound...
Old 01-11-2013, 09:53 PM   #4
Gymschu's Avatar
Rewards Points: 490
Joe, the Bright White (SW) is a flat ceiling paint.
I've used a lot of SW's bright white ceiling paint and used to have great luck with Classic 99. THey changed the formula and now call it Brilliance which doesn't cover as well as the Classic 99 did. I would use the Promar 200 flat or the SuperPaint flat for ceilings.
Old 01-12-2013, 12:17 AM   #5
ltd
Rewards Points: 536
I use super paint flat extra white it has a very slight sheen ,only if you look at it on an extreme angle. the extra white is my go to ceiling color ,and for that matter ill use the same extra white on trim but in a semi. Any who. imho pro mar 200 in a flat is junk . the other sheens are good but a flat
ltd is offline   Reply With Quote
The Following User Says Thank You to ltd For This Useful Post:
Gymschu (01-12-2013)
Old 01-12-2013, 05:39 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 234
say what?????????????
you crack me up
Old 01-12-2013, 05:43 AM   #7
chrisn's Avatar
Rewards Points: 234
plain white super paint
as you have already found out the "bright" white is "bluer"
Old 01-12-2013, 06:18 AM   #8
Why the sky is blue. Against "bright" or super white, most whites look grayer.
Old 01-12-2013, 07:51 AM   #9
chrisn's Avatar
Rewards Points: 234
Originally Posted by toantapsimg View Post
<br />
<br />
Ki?m ti?n tr?c tuy?n không dòi h?i b?n ph?i t?n quá nhi?u th?i gian v* công s?c v*o nó, ch? c?n m?t v*i gi? m?i ng*y ho?c v*i ch?c phút cung du?c dó l* tùy ? b?n. Tru?c dây tôi l*m r?t nhi?u vi?c v* t?n r?t nhi?u th?i gian (m?i ng*y 3-4h) nhung k?t qu? thì ch?ng du?c gì. Tôi dã tìm ki?m, dã th? r?t nhi?u vi?c v* gi? dây SFI l* s? t?p trung h*ng d?u c?a tôi.
I agree with the above
The Following User Says Thank You to chrisn For This Useful Post:
Old 01-12-2013, 08:17 AM   #10
Im using promar 200 flat... Im confused, I thought flat is the sheen not the color. Are you saying pm200 flat sheen with no tint?
Old 01-12-2013, 08:19 AM   #11
you crack me up
Is it true the bright white will show more?
Old 01-12-2013, 08:31 AM   #12
Rewards Points: 5,974
LOL I'm a painter and they have me confused.
Old 01-12-2013, 08:49 AM   #13
Rubbin walls since'79
Brushjockey's Avatar
A- nobody is answering your q-
The color makes no difference ( well somtimes but not much) but the sheen and how the light hits it is everything for showing flaws.
If you have west facing windows that come close to the ceiling, stand ther at the east end and look. bumps will become mountains.
Because a paint with any shine reflects light- it will have this effect in almost any light.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 01-12-2013, 08:59 AM   #14
Sheen and color are two different things. The way it's being presented is confusing, nice kickoff joecaption.
Firstly, there is no standard white, as all whites are different. Even in the same brand the whites will differ, within the same and across the different lines. BM offers Brilliant White, Super White, Decorators White, etc. And that doesn't include the whites with a tint or shade, like Navajo White, Dove White, etc.
Some straight whites have higher a content of titanium dioxide, which would be brighter, purer whites. Others are shaded with black to increase hide, which makes them grayer in comparison to the purer whites. However, you wouldn't really be able tell they're grayed unless you compare them to pure white.
Some people confuse eggshell sheen with color, thinking eggshell is a color.
All colors can be made in all sheens, though massive amounts of tint even in a dead flat paint will create a sheen. Tint is not flat. For a ceiling the preferred sheen is flat. A dead flat, almost or zero sheen, will mask defects on a ceiling because it doesn't reflect light. I would disagree with Joecaption that a brilliant white will highlight defects. Pure white has little definition in itself, which would aid in hiding defined defects. Pure white will "snowblind" you when looking at a ceiling. Color adds definition.
The Following User Says Thank You to jsheridan For This Useful Post:
Old 01-12-2013, 10:11 AM   #15
Gymschu's Avatar
Rewards Points: 490
Thanks, Joe, as always the right information in clear, concise words that we all can understand.
The Following User Says Thank You to Gymschu For This Useful Post:
jsheridan (01-12-2013)
Color Matching unpainted drywall ceiling wvphysics Drywall & Plaster 2 11-26-2010 11:21 AM
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 01:15 PM
Ceiling paint problems, and color? mara Painting 6 08-02-2008 03:23 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
Transform Ceiling Beam to Oak Color WorkerBee Painting 1 01-06-2008 04:04 PM
