Old 03-28-2011, 08:30 PM   #1
Ceiling canister lights
Can the inside (gold-plated) of a canister light be painted to a more contemporary stainless steel type of paint?
Rose_ is offline   Reply With Quote
Old 03-28-2011, 10:30 PM   #2
Super Master Painter
Ole34's Avatar
Rose? thats a pretty name..........anywho
about the only things that cant be painted are water, air, bad breath and ummm that's about it..............scuff the lights up with some sand paper then prime with a good bonding oil primer (I recommend Zinsser Cover Stain)then 1-2 coats of enamel finish paint.......you dig?
or you could just scuff them up and spray them with a can of Krylon metallics
Ole34 is offline   Reply With Quote
The Following User Says Thank You to Ole34 For This Useful Post:
Rose_ (03-29-2011)
Old 03-29-2011, 05:17 AM   #3
paper hanger and painter
chrisn's Avatar
What about the heat?
The Following User Says Thank You to chrisn For This Useful Post:
Rose_ (03-29-2011)
Old 03-29-2011, 05:55 AM   #4
Super Moderator
The trim rings can be replaced for about $12.00 each----I'd consider that option.--Mike--
Old 03-29-2011, 08:06 AM   #5
Coatings Nerd
She wants to paint the inside of the light. Yes, you can paint them. You can paint the outside rings too.
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
The Following User Says Thank You to NCpaint1 For This Useful Post:
Rose_ (03-29-2011)
Old 03-29-2011, 08:07 AM   #6
Coatings Nerd
If heat is that big of a concern, its time to change to a lower wattage High Efficiency bulb.
Old 03-29-2011, 04:32 PM   #7
Ole34's Avatar
heat?? ..... i call that ''baked on enamel'' an charge extra for that ......same goes for radiators
Old 03-29-2011, 05:15 PM   #8
chrisn's Avatar
Well,I'm glad you will not be painting anything in my house
Old 03-29-2011, 07:30 PM   #9
I tried to spray the cannister insides gold once for a customer, it melted the inside of the cannister. Step lightly. Krylon makes a latex spray paint, which I just used, it's okay. That might be considered rather than exposing cheap plastic to toluene.
The Following User Says Thank You to jsheridan For This Useful Post:
Rose_ (03-29-2011)
Old 03-29-2011, 11:06 PM   #10
Thanks, I have over a dozen canisters throughout the house, that's why I was trying to paint instead of replacing.
need help removing ceiling fan and installing recess lights craig83170 Electrical 1 09-06-2008 08:27 PM
ceiling & wall lights diynovice1 Electrical 5 07-30-2008 03:10 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
Work lights in basement with drop ceiling fw2007 Electrical 2 10-20-2007 10:39 AM
halogen lights fitted into a polystyrene ceiling - safe? jono_wales Electrical 1 03-07-2005 03:52 PM
