Old 03-13-2009, 09:13 AM   #1
Cedar Wood Fence - Staining again
Last year, we installed a 425ft Cedar fence around our yard. We stained the fence with Cabot Stain, which we were told to do only 1 coat.
Over the summer the fence started to look more and more like the stain had been absorbed into the wood, thus making the fence look like it was not entirely stained.
We were told to stain it again, that it should have been 2 coats and not 1. So my question is how should I prepare the fence before we stain it again? Some areas of the fence have 'dark spots" or mildew. Should I clean the fence with any solution or water before staining again?
Also, has anyone use a pump sprayer with Cabot stain (oil)? Painting the fence with a roller and brush took 2 days..
Thanks for you help
ddave23 is offline   Reply With Quote
Old 03-13-2009, 09:20 AM   #2
Remodeling Contractor
Clean with TSP and a pressure washer. Rinse thoroughly! Rent a sprayer, HVLP or airless will both work fine. Stay away from a pump sprayer or cheap units like a wagner sprayer. Use two coats.
Old 03-13-2009, 01:58 PM   #3
Make sure you use a product when washing your fence that kills the mildew. I generally use Jomax and Bleach and I run these through my powerwasher. I also agree that 2 coats should then be applied. I would rent an airless.
waynech is offline   Reply With Quote
More On This Topic
Use cedar oil in distilled form to reinvigorate old cedar wood in closets, shavings, sachets, balls and chests. It will also repel moths. Follow these tips. Read More »
Now as you could see here I got the stain on the front and what you need to do is let say that the stain was not actually dark enough. That the stain was not the color that I wanted what I have to do is actually wait between 8-24 hours to give this stay... Read More »
Maybe your vinyl fence is looking a little worn. Or, perhaps you want to change the color of it. Painting a vinyl fence is possible but you need to buy the correct kind of primer and paint. Not just any paint will adhere to the vinyl surface. Follow... Read More »
Deck wood should be carefully and properly maintained through the entire year. It should be consistently treated with the best quality cleansing products on the market. Preparing deck wood takes particular skills in order to treat wood properly. Read More »
On preservation of your fence, you might want to think of painting your fence every three years depending upon your environment. Now, touch up as needed. Make sure that you save a sample of the original paint. When you do your touch up, the paint will... Read More »
DIY Replacement of a Wood Fence rcraftlady Building & Construction 4 03-11-2009 07:03 PM
Staining our fence? Shpigford Painting 2 07-23-2008 06:07 AM
Ready to paint the porch! Oil or latex? Leah Frances Painting 5 07-07-2008 09:33 PM
Staining Wood Fence art2670 Carpentry 2 11-14-2007 01:15 AM
Preferred Fence Wood? Medium_Pimpin' Building & Construction 2 07-06-2007 10:21 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
