Cedar Siding Scraping Questions.. - Painting - DIY Chatroom Home Improvement Forum
Old 06-17-2012, 09:53 AM   #1
2 steps below newbie...
Cedar siding scraping questions..
Im going to be tackling re-staining my cedar board/batten house this summer and want to start scraping it..
I picked up a couple husky scrapers from HD and upon doing a couple test spots seems like I'm simply just scraping the wood away..
Is this simply a result of the wood being so weathered and soft (house built in '78) or do I have the wrong/to aggressive of a scrapper?
To be fair this is the most weathered side as it faces the south. The North side is much darker and smoother to start with it, but still seems like I could scrape down to almost new wood with little effort.
In the first photo, Im trying to show the ridges in the wood and the lighter spots is about 2 passes over with the scrapper. The right photo the lighter circle is where I simply rubbed with my thumb to show how soft/poor it seems. Perhaps I shoudln't be scrapping but brushing with something? Last photo is simply a distance shot of the first two..
I bought the house in spring '10. I'm unsure of when it was last stained or what products were used as the number of the business the previous owner left is now out of business.
Hopefully this all makes sense...
This is what I'm scrapping with...
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
Dieselbear is offline   Reply With Quote
Old 06-17-2012, 10:12 AM   #2
Renovations contractor
Bonzai's Avatar
That tool is for scraping loose paint off of smooth walls or vinyl tile adhesive off of floors or such things. Cedar is a soft wood with a rough texture surface and stain penetrates the wood. By scraping all you are doing is removing the surface of the wood and damaging it. You will not remove the stain even by sanding as it has penetrated beyond the surface (unless you remove a few mm from the whole house which obviously isn't practical) . Cedar especially is a very porous wood. Basically, as long as the wood is not rotten and the surface is not flaking or brittle you can apply a new coat of stain over the existing ... But obviously you have to go for the same or darker shade.
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 06-17-2012, 12:26 PM   #3
Gymschu's Avatar
Rewards Points: 514
Bonzai is right, there's nothing to scrape. You have rough sawn cedar that has NOT been painted. You will have to decide if you want a clear coat to maintain the cedar look or if you want to stain it to a different color. The only prep you really need is a thorough cleaning.........very gentle pressure washing or a good scrub down with some warm water and a soft-bristled scrub brush.
Gymschu is online now   Reply With Quote
Removing vinyl siding from cedar mikegyver Carpentry 1 02-17-2011 08:47 PM
Roof to Wall Flashing Installation Painted Cedar Lap Board Siding Deeppool Roofing/Siding 3 12-08-2010 08:36 AM
Repairing Cedar Siding WBNC Painting 1 08-03-2009 05:20 PM
Installing fiber cement siding over existing cedar siding heron Remodeling 3 07-25-2009 12:17 AM
Questions about paint prep for exterior cedar siding. 240sx4u Painting 4 09-22-2008 11:46 PM
