Cedar Railings On Deck - HELP! - Painting - DIY Chatroom Home Improvement Forum
Old 07-04-2009, 10:44 PM   #1
Cedar Railings on Deck - HELP!
bought 8 yr old house with Trex decking & cedar posts/rails/spindles that previous owner painted with latex. Top boards (approx 8 inches wide by 4-5 ft long by 2 inches) had paint flaking off. I sanded smooth, primed with Sherwin Williams A100 and top coated with Duration. Paint bubbled bubbled (air pockets). Stripped again, this time I used exterior spackle and skim coated / sanded in case there was something on the wood ... same story - bubbled worse. So, now I am thinking sand one more time, try exterior KILZ and see if the primer will hold. Duration on spindles/bottom rail looks great. Top board/rail is the issue. I was also thinking about putting some sort of gloss white vinyl cover on the top rail and averting this issue altogether! Can't locate anyone who does this. Any advice??? Thanks!!!
griffithfam is offline   Reply With Quote
Old 07-04-2009, 10:58 PM   #2
Haste Makes Waste
Although I've never used it, Melamine paint may be an answer. Wait for the pros to guide you on this problem though. I have read about the Melamine paint (which is basically liquid plastic) and according to info can be applied to any finish and it will dry to a hard, smooth finish like plastic. It might be an option for you.
saggdevil is offline   Reply With Quote
Old 07-08-2009, 09:02 PM   #3
Coatings Professional
Justabottle's Avatar
Usually bubbling paint is the result of top coating too soon.
If the primer does not have enough time to fully dry the solvents will become trapped and cause the top coat to bubble.
When you peel up the bubble is there bare wood under or do you see the primer still?
If you see bare wood then moisture is the culprit.
Justabottle is offline   Reply With Quote
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
How do I secure deck railings between posts tigereye Building & Construction 19 05-10-2009 04:49 PM
cedar deck looks like crap silky Painting 16 05-02-2009 10:42 PM
New Cedar Deck johnjpas34 Building & Construction 7 09-06-2007 09:16 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
