Caulking Question - Painting - DIY Chatroom Home Improvement Forum
Old 08-20-2013, 09:34 PM   #1
Rewards Points: 101
Caulking question
I have a concrete balcony over metal sheathing supported by metal crossbeams. Water has been seeping through gaps in the front of the deck between the concrete and beam where rain water rolls off. It seeps through the back of the beams and causes corrosion and paint damage. I have cleaned out, sanded, primed with rust converter and caulked the front with silicone II.
My question is should I caulk the back or leave it open in case any moisture makes it through the front so it can dry out?
r1racer is offline   Reply With Quote
Old 08-21-2013, 10:30 AM   #2
Rewards Points: 101
anyone?
Old 08-21-2013, 12:08 PM   #3
ask4dan's Avatar
More info please...
Is the middle picture the inside view?
ask4dan is offline   Reply With Quote
Old 08-21-2013, 12:25 PM   #4
Rewards Points: 101
Middle picture is underneath the balcony (other side of the beam in first two pics). I removed all of the old caulk.
Old 08-21-2013, 12:47 PM   #5
ask4dan's Avatar
Trust your instinct!
Being you've "fixed" the leak. Let it breath. If you clean up the underside of the balcony; any future 'leaking' should be come noticeable. Hopefully the concrete is not saturated and migrating the water. Is the metal a pan that the concrete was poured into? e.i. Open riser metal pan steps that you'd see on the exterior of a hotel or commercial building?
Old 08-21-2013, 02:17 PM   #6
Rewards Points: 101
Makes sense. It's possible that moisture is getting through the concrete as well but I am pretty sure 90% was from the uncaulked gaps. Whoever painted last only caulked underneath the balcony and it wasn't silicone.
Not sure what kind of pan but the underside has metal beams running every 16 inched or so. The original builder was a commercial contractor so it's possible.
Thanks for your help.
Old 08-21-2013, 05:25 PM   #7
ask4dan's Avatar
Talking
Rigid sponge!
Just some food for thought...
Concrete is just a rigid sponge, like electrons; water follows the path of least resistance and as such - it if really hard to in point the source of the "leak".
With everything you've already done - a good insurance policy would be to seal the surface of the concrete porch slab. I have a couple personal preferences for products; but posting them wouldn't be proper, here. One is acrylic and does a pretty good job for a couple years, the other is a silicone alkyd based product that I discovered about 25 years ago that I've seen last for 2 centuries and still looks nearly as good as it did when it was applied - its' lost a little bit of its' shine. Only problems with the latter, are:
you can't maintain it it with anything but itself - nothing will adhere properly
and hope they NEVER go out of business - see the next bullet...
they are now owned by XXX and the $ has sky-rocked in the past couple years.
As for the acrylic one; it was mentioned in another post by brand name, I'll reserve my opinion on the recommended application directions offered. The one named WOULD NOT work; in your case, but another product in their line would.
Old 08-21-2013, 08:38 PM   #8
Rewards Points: 101
Do you mind PM the brands?
Old 08-22-2013, 01:13 AM   #9
paper hanger and painter
chrisn's Avatar
Rewards Points: 392
you can certainly post brands here
Old 08-31-2013, 09:54 AM   #10
Rewards Points: 101
Just an update...everything turned out great. Couldn't be more pleased. Thanks again for your help.
Caulking question-balc.jpg   Caulking question-balc2.jpg   Caulking question-balc-3.jpg
The Following 3 Users Say Thank You to r1racer For This Useful Post:
ask4dan (08-31-2013), cdaniels (08-31-2013), ToolSeeker (08-31-2013)
Old 08-31-2013, 10:08 AM   #11
Gymschu's Avatar
Rewards Points: 832
Thanks for posting the "end result." So often someone asks questions and gets advice but never lets us know how it turned out. It looks great!
An easy Question rick31797 HVAC 4 04-09-2012 08:14 PM
simple caulking cleanup question utilitylocator Plumbing 4 02-11-2009 11:13 AM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
