Caulking And Painting - Painting - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 09:52 PM   #1
Caulking and painting
Is it best to caulk around edge of sink that meets wall and to caulk trim before or after painting?
Jordmiller is offline   Reply With Quote
Old 03-01-2012, 09:55 PM   #2
Yes, and before, respectively. And bring your paint out over the caulk between the sink and wall.
Old 03-01-2012, 10:00 PM   #3
GE Groov Tub and Bath is good paintable silicionized latex caulk.
DAP Alex plus is another one. Don't get plain silicone caulk if you plain to paint over it.
If you don't plan to paint it, I like GE silicone caulk.
cousindan is offline   Reply With Quote
Old 03-01-2012, 10:05 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
Implied in above but I want to make really clear- DO NOT USE 100% SILICONE CAULK anywhere that will ever be painted.
Clear?
if it doesn't say paintable on it, it probably isn't , and will repel paint for a half life of a gigillion years. Really.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 03-02-2012, 03:52 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 388
Clear?
Wow, that's a loooooooooong time
Old 03-02-2012, 07:13 AM   #6
Yes. yes it is.
Old 03-02-2012, 08:50 AM   #7
Rewards Points: 101
Yes it's a good idea to caulk where the sink meets the wall. Also when caulking your trim do it after the rim is primed. Never caulk bare wood, the bare wood will suck the moisture out of the caulk and it will crack.
JMDPainting is offline   Reply With Quote
Old 03-02-2012, 04:27 PM   #8
chrisn's Avatar
Rewards Points: 388
About the same amount of time it is going to take to break down the trillions of tons of plastic sheeting we will be disposing of when complying with RRP
Old 03-02-2012, 05:05 PM   #9
Rewards Points: 626
I use Quad Caulk it is the bomb! it can be painted it last for ever ok 10 to fifteen years never yellows.and Caulk then paint.
Nailbags is offline   Reply With Quote
Q about poor air quality after ext. caulking rational HVAC 8 08-10-2011 02:49 PM
Proper Vinyl Window caulking With Hardi-plank fitzofury Remodeling 2 04-26-2010 01:33 PM
Caulking concrete basement wall/floor before painting abledsoe Painting 0 01-10-2010 09:43 AM
Caulking...Priming & Painting with Tape saggdevil Painting 3 05-19-2009 10:42 AM
caulking trim before painting ponch37300 Painting 10 05-15-2009 10:16 AM
