Caulking The Gaps - Painting - DIY Chatroom Home Improvement Forum
Old 07-16-2012, 11:26 AM   #1
Rewards Points: 296
Caulking the gaps
Flat baseboard on a slighly wonky wall.
It's nailed nice and tight with some gaps here and there from the wall.
With good old BM 464 caulk...do I just run a tight bead and just tool it. Or am I better taping both sides and then tooling it. I have not used this stuff in ages..
mobiledynamics is offline   Reply With Quote
Old 07-16-2012, 12:30 PM   #2
Rewards Points: 14,306
No tooling or tape ever needed.
Get a small bowl of water and a stiff sponge, the ones with the Scotch Brite pads on the back work best.
Make a very small hole in the tip, only use a tiny amount of caulking, wipe on with your finger, then wipe down with a damp sponge, then hit it one more time with your finger.
There should only be caulking in the gap, none on the wall or trim if it's done right.
Old 07-16-2012, 12:59 PM   #3
Rewards Points: 296
Double tooling with a sponge in between.
As long as I'm not spreading gobs....and it's tooled good, that was the plan of attack.
This is the 1st I've read of triple tooling...
Wipe, sponge, wipe. Is this a common tricks of the trade routine ?
I'll do the whole tape / mineral spirits routine with silicone or fully urethane stuff, and even with that, it's a single swipe/tooling with mineral spirits.
Old 07-16-2012, 01:06 PM   #4
The spong will leave a spot at the end of the wipe and it's rough so the finish is not smooth. Once the caulking get damp a quick wipe with a finger will leave it glass smooth.
Once you try it you should be able to do a whole bed room in less then 1/2 hour including window trim and door trim.
Old 07-16-2012, 03:26 PM   #5
Too Short? Cut it Again!
Clean the surface to be caulked of any debris or rough edges. I pipe out an appropriate size bead of caulk, tool it with my finger and wipe the excess with a damp terry cloth. I see no reason to have to go over it twice unless you have particularly wide or otherwise large gaps in places.
Remember you cannot paint silicone! You can get paintable caulk with some silicone in it for flexibility but pure silicone is a nightmare. It is a Royal PITA to carve out of the way if it fails or moisture gets under it or behind it too.
Tape will serve no helpful purpose and you will end up with a ridge of material next to it if you use it. Do get a quality caulking gun. The ones that swivel are especially nice but definitely get one with nice ratchet action.
If you have some laying around, wire nuts make great caps for tubes of caulk.
Old 07-16-2012, 05:21 PM   #6
Rewards Points: 296
I use BM 445 cause I like the paintable urethan properties of it.
I've stopped using wire nuts. I usually end up squeezing out a bit for the excess forms a cap - when I need to reuse, I just pull off the hardened excess and viola.
Old 07-17-2012, 04:16 AM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 612
Any quality gun will be or say DRIPLESS, very important
I work with another paperhanger painter friend from time to time and she still uses these $3.99 guns from blowes, drives me nuts
chrisn is online now   Reply With Quote
Bathroom floor/tub and caulking soulstar General DIY Discussions 5 11-10-2011 10:49 PM
Caulking large gaps in shower enclose+to caulk or grout a tub with tile. pilsengirl Plumbing 1 07-31-2011 12:36 PM
caulking cedar siding gaps amakarevic Building & Construction 12 06-29-2011 04:13 PM
Caulking Exterior Windows unixb0y Painting 1 06-04-2009 05:31 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
