Caulking Crown And Base - Painting - DIY Chatroom Home Improvement Forum
Old 12-11-2010, 06:35 PM   #1
Rewards Points: 274
caulking crown and base
Do painters usually caulk where crown meets wall & ceiling, or only in spots where needed?
ugabulldog is offline   Reply With Quote
Old 12-11-2010, 07:08 PM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
It is our practice to caulk anyplace where trim meets the walls as needed. If there is no gap, then it doesn't need caulk. I know quite a few other painting company's that also caulk where trim meets walls. We also calk the trim at the corners and joints if it needs it too.
housepaintingny is offline   Reply With Quote
Old 12-11-2010, 07:23 PM   #3
DIY staff
Rewards Points: 7,174
We caulk the entire length--wherever trim meets drywall.
Old 12-11-2010, 07:30 PM   #4
Rewards Points: 274
Let me expand my question please,.....Is it standard practice to caulk pre-hung doors where they meet wall, and where casing meets frame, and where the two pieces of door frame meet in miidle at stop? I am also assuming that base board should be caulked where it meets walls, correct?
And what's a good paintable caulk?, Not 100% silicone, right? Thanks
Old 12-11-2010, 08:39 PM   #5
Rewards Points: 616
Yes, standard practice. We always use Sherwin Williams 850a or 950a they are both an acrylic silicone blend paintable caulk, so you get the benefits of silicone and acrylic.
Old 12-12-2010, 12:22 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 312
NO!
Crown molding to arched window tas10000 Carpentry 5 09-17-2010 03:35 PM
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 07:18 PM
15 or 16 gauge nailer for larger MDF Crown Klawman Carpentry 2 11-10-2009 01:16 PM
crown over cabinets in wonky house Brik Carpentry 5 03-20-2009 04:22 PM
Door framing and crown molding finnishing question amdspitfire Painting 7 06-09-2008 01:49 PM
