Caulking Baseboards - Does It Look Good? - Painting - DIY Chatroom Home Improvement Forum
Old 01-08-2008, 04:04 AM   #1
Caulking Baseboards - Does it look good?
I just finished painting the wall and even after taping off the baseboards, it still did not look aesthetically pleasing, so I caulked between the wall and baseboards with a white paintable silicone caulk. I decided to leave it WHITE and NOT paint it.
Do you think it looks "professional" or should I paint the caulk with the wall color??
JackOfAllTrades is offline   Reply With Quote
Old 01-08-2008, 06:14 AM   #2
Tired, Cold, and Damp
slickshift's Avatar
Wall color
To be honest, if that's stained trim, it's traditionally (almost never) caulked
Of course, every once in a while it happens
slickshift is offline   Reply With Quote
Old 01-08-2008, 06:50 AM   #3
Guest
Guest
Posts: n/a
Usually if I were to caulk stained trim I'd think a clear caulk would look best. That's about the only way I've ever seen it done.
Old 01-08-2008, 10:14 AM   #4
Originally Posted by slickshift View Post
Wall color
It is a maple wood stained baseboard. Originally, it had a white latex caulk bead going over the lip of the baseboard where the wood met the drywall.
The problem was that the lip on the baseboard that did not come-out looking right. I taped it off before I painted but the latex paint "built-up" in and around that lip. So there was a ridge of paint on the baseboard lip and it looked sloppy. Even after trying to scrape it away, all it did was ruin the wood lip.
That is when I decided to just caulk it to give it a "clean" look. Now, I just don't know if I should leave it white or paint it the wall color????
Old 01-09-2008, 12:21 AM   #5
Do anything other than leave it white. I probably would have used "cedar tan" colored caulk instead of white. You might be able to go over the white caulk with the cedar tan caulk, but it will probably build up too thick. Just paint the white caulk the wall color. It will look WAYYY better.
send_it_all is offline   Reply With Quote
Old 01-09-2008, 01:48 AM   #6
Paint it the wall colour for sure
jsdennis22 is offline   Reply With Quote
Old 01-09-2008, 07:40 AM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
As stated, stained trim is usually not caulked. When it is, it's generally, a color-matched caulk. Since you have caulked it already, your only alternative is to paint it the wall color now (as others have already suggested).
Good Luck.
- Build Well -
Old 01-09-2008, 10:08 AM   #8
I think it should be painted so that the stained wood stands out against it and the wall.
End Grain is offline   Reply With Quote
Old 01-10-2008, 11:14 AM   #9
Thanks for all the input! The verdict is in. I will PAINT it the wall color. I will post a pic showing the results.
THANKS!
Old 01-10-2008, 03:10 PM   #10
BleachCola's Avatar
what about painting all the trim white?
BleachCola is offline   Reply With Quote
Old 01-10-2008, 03:41 PM   #11
The baseboard/trim is real wood maple. The wood tone will always look better than just plain white. Actually, the wood trim was an "upgrade" as the standard trim was just white painted cheap wood.
Old 01-10-2008, 09:17 PM   #12
I painted the caulk. Much better. Thanks for the advice:
Old 01-11-2008, 08:08 AM   #13
I always caulk along trim,stained or not. I think what you've looks great,a nice finished edge.
white29 is offline   Reply With Quote
Old 01-13-2008, 10:51 PM   #14
Workaholic's Avatar
I came to late, i would of told you to go wall color for sure. Glad to see you did it and it looks much better. Congrats
Sean
Workaholic is offline   Reply With Quote
Are they good Shenandoah Cabinets good quality? robertmazzo Carpentry 76 05-14-2015 10:23 PM
Looks like a good Christmas this year! leroyme Off Topic 6 12-23-2007 11:45 AM
Keeping caulking trick deck hand Tools 8 11-15-2007 09:53 AM
HELP: Bleeding Baseboards Roztom1 HVAC 2 10-11-2007 04:10 PM
