Caulking Around Pipe - Painting - DIY Chatroom Home Improvement Forum
Old 06-21-2009, 12:09 AM   #1
Rewards Points: 260
Caulking around pipe
I need to caulk around a 2" pipe that goes through my siding. The hole is slightly larger, so there is a 1/4" gap that needs to be filled. Should I use some type of material to fill the gap before applying the caulk?
bluefitness is offline   Reply With Quote
Old 06-21-2009, 07:57 AM   #2
Some foam backer rod will be your friend here.
slickracer is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Newbie Solder Question SteveSmith98 Plumbing 9 01-15-2009 10:50 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 06:40 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
