Caulking - Painting - DIY Chatroom Home Improvement Forum
Old 05-19-2009, 09:05 AM   #1
Haste Makes Waste
Caulking
Should caulking be done before or after priming?
Also, I have beautiful 1913 woodwork. There is a slight gap between wood and wall; should I caulk this area?
saggdevil is offline   Reply With Quote
Old 05-19-2009, 09:21 AM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
Preferably after priming. It will hold onto the primer better than it will bare wood.
Old 05-19-2009, 10:16 AM   #3
Haste Makes Waste
Caulking
If I caulk after priming, do I need to remove tape and re-apply prior to painting to avoid a caulk edge? I've had this happen leaving tape on too long after caulking before. If I need to remove and reapply, then I can see why the DR, LR and Foyer have never been caulked. The DR has three large windows, 3 single doorways, a double doorway and a large ornate mantle. All these rooms (the entire house) has a lot of trim, etc. That's a lot of taping.
Old 05-19-2009, 10:21 AM   #4
Haste Makes Waste
Caulking woodwork/wall area
strait tape lines & caulking? joe1 Painting 4 04-13-2009 12:31 AM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 05:46 PM
Tuckpointing vs. Caulking NewUser1 Building & Construction 2 07-09-2008 09:33 AM
Need help with caulking problem and fuzzy wood! Beth777 Painting 4 07-04-2008 04:06 AM
Keeping caulking trick deck hand Tools 8 11-15-2007 09:53 AM
