Caulking - Painting - DIY Chatroom Home Improvement Forum
Old 11-22-2011, 11:05 PM   #1
Caulking
I was removing the caulk from my fiberglass tub enclosure with a caulking softner and the product became gooey, stickey and ended up on the the painted walls just above the caulk line. Does anyone have any suggestions how to remove the "stickiness" of the caulk from the paint. In some areas I was using the caulking tool so much that the backerboard was exposed. Was planning on painting the bathroom anyway, but am thinking I'll probably need to let it dry,then sand and spackle. Thanks for any advise.
debbieindy is offline   Reply With Quote
Old 11-23-2011, 05:42 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 124
What was it?
Old 11-23-2011, 07:05 AM   #3
I've never even heard of a "caulk softener", but I can tell you right from the start I wouldn't use it if I did, and for the exact reason you're suffering. It sounds like a guaranteed mess. There is no substitute for a sturdy razor blade and scraper, dry removal, for removing caulk. As to your question Debbie, you answered it yourself. Good luck.
Joe
The Following User Says Thank You to jsheridan For This Useful Post:
canadaclub (11-24-2011)
Old 11-23-2011, 10:29 AM   #4
chrisn's Avatar
Rewards Points: 124
Joe
Thats why I asked, maybe there is actually something we don't know
Old 11-23-2011, 03:07 PM   #5
Nah. Could there be?
Old 11-23-2011, 05:50 PM   #6
chrisn's Avatar
Rewards Points: 124
I would be completly surprised
The Following User Says Thank You to chrisn For This Useful Post:
jsheridan (11-23-2011)
Bathroom floor/tub and caulking soulstar General DIY Discussions 5 11-10-2011 11:49 PM
Caulking a Bathtub, need advice RealMarkP Plumbing 5 03-12-2011 06:25 PM
caulking tile backsplash--he sprayed something on the caulking then used his finger Limit54 Tiling, ceramics, marble 6 12-06-2010 06:45 PM
Caulking Exterior Windows unixb0y Painting 1 06-04-2009 06:31 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 05:46 PM
