Caulk Recommendation - Painting - DIY Chatroom Home Improvement Forum
Old 12-09-2008, 12:02 PM   #1
caulk recommendation
any recommendation for which caulk to use on interior trim such as baseboards, casing and crown moulding.
wpgtkd is offline   Reply With Quote
Old 12-09-2008, 02:11 PM   #2
Rewards Points: 2,906
If it were me, I would use a latex caulk (not "chaulk"). And "sponge caulk" the joints. That is, after appling a THIN bead of caulk over the joint, wipe it into the joint with your finger and then use a damp sponge (rinsed out frequently) to clean the remaining caulk off.
The result is that the joint between the door frame and drywall (say) is filled but there's no visible bead of caulk between the two. Then you can paint over that caulk and it looks perfect.
Nestor_Kelebay is offline   Reply With Quote
Old 12-09-2008, 03:07 PM   #3
Workaholic's Avatar
I use 55 yr elastomeric caulk. It will flex rather than crack.
Sean
Workaholic is offline   Reply With Quote
Old 12-09-2008, 08:16 PM   #4
Rewards Points: 506
You want Siliconized Paintable Elastomeric Latex. I use DAP Dynaflex 230, others here have reported good luck with White Lightning. Sherwin owns White Lightning and sells their own line, which should be of similar quality.
Avoid GE Caulk like the plague.
SirWired
sirwired is offline   Reply With Quote
Old 12-09-2008, 08:27 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
...DAP Dynaflex 230
...White Lightning.
...Sherwin sells their own line
...Benjamin Moore's house brand
...Phenoseal
All good when you get up to the 35/45/55 year mark
(the increase in "years" is a general indication of quality)
Yup
Maybe it's great for your washing machine, refrigerator, or nuclear bomb, but as a house painter's caulk...not so much
slickshift is offline   Reply With Quote
Old 12-10-2008, 12:46 AM   #6
Gentlemen:
I think we all have to recognize that appearance plays a vital role here. The purpose of a caulk around a crown molding isn't to stop drafts; it's to hide the gap that's gonna show up between the crown molding and wall or ceiling. I don't know which would look worse, that gap, or a bead of caulk covering it.
That's why I'm suggesting the OP use a water based caulk (and the name of the caulk or manufacturer is irrelevent) and follow up by wiping off any caulk that isn't in the gap with a damp sponge. That way you have neither a gap nor a bead of caulk to look at. You end up with crown molding (or door frame or baseboard) that looks like it fits to the wall or ceiling perfectly.
Can we agree that the best option here is to have what appears to be NO seam between the moldings and the surrounding surfaces rather than a bead of caulk between the moldings and surrounding surfaces? And, you can only do that easily with a water based caulk so that you can remove the excess caulk with a damp sponge.
Old 12-10-2008, 06:01 AM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
For interior use: Any latex based caulking will work.
- Build Well -
Old 12-10-2008, 10:16 PM   #8
Rewards Points: 506
The problem I have had with the non-elastomeric caulks is that they get so hard over time, and will not expand and contract with the wood as well as the more flexible elastomerics. This leads to cracks sooner rather than later.
SirWired
Old 12-10-2008, 10:22 PM   #9
Rewards Points: 150
the cheapest latex painters caulk that you can find.
drewhart is offline   Reply With Quote
Old 12-11-2008, 03:19 PM   #10
bradnailer's Avatar
That's what I'd use.
bradnailer is offline   Reply With Quote
Old 12-12-2008, 04:15 AM   #11
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
And the reason being?
Old 12-12-2008, 07:47 AM   #12
Man of many hats
wrangler's Avatar
Rewards Points: 354
Personally, I have had great luck with siliconized latex such as Alex Plus. It is inexpensive, paintable and will expand and contract with temperature changes and slight shifts. And for larger voids, such as chips in the wood, bad joint due to walls etc, fill the void, then wet your finger and lightly rub across the void. Once painted it will be virtually invisible.
Man of many hats
wrangler is offline   Reply With Quote
Old 12-12-2008, 08:48 AM   #13
bradnailer's Avatar
Because latex caulk is more paintable than the siliconized types and the project is only filling small gaps and once it is all painted there will be very little if any wood movement.
Old 12-12-2008, 09:21 AM   #14
Rewards Points: 150
yeah thats why. and because thats what i have been using for years under the same logic with no problems ever.
Old 12-13-2008, 06:20 AM   #15
chrisn's Avatar
Rewards Points: 120
How do you know this fact?
$200-300 paint sprayer recommendation ponch37300 Painting 10 12-05-2008 04:46 PM
Landscape Design in Southern California Recommendation? just_another_guy Landscaping & Lawn Care 1 06-20-2008 05:49 PM
Recommendation for roof tile needed johnnymg Roofing/Siding 1 05-10-2008 04:10 PM
Need recommendation for type of kitchen cabinet paint MBScott Painting 10 09-08-2006 10:12 AM
