Caulk Question: Paint First Or Caulk First Then Paint? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-05-2013, 07:42 AM   #16
Wow, thanks for all of the great replies! I will think about the 1/4 round while I spackle some holes.
I think the cracks are due to settling, but I'll find out more when I strip out the old caulk.
Drew
drew2000 is offline   Reply With Quote
Old 07-05-2013, 08:49 AM   #17
Ok guys, here is my update. I started pulling off the caulk with a razor blade. It looks like the caulk was just used to "finish" the gap between the shelf board and the dry wall. It doesn't look like there is a drywall seam underneath.
As I was carefully peeling the caulk, I tore some of the drywall paper.
What is the best way to handle this? I know (from past experience) that painting over the tear will not hide the ridge. I was thinking of trying to feather it using medium grit sandpaper. Or perhaps using drywall compound to smooth it over.
This is all a learning process as I am trying to improve my skills.
Drew
Caulk question:  Paint first or caulk first then paint?-photo.jpg
Old 07-05-2013, 10:51 AM   #18
I ended up using drywall compound to smooth it out. Will sand once dry!
Drew
Old 07-05-2013, 09:11 PM   #19
Painting Contractor CT
Rewards Points: 77
Post
Definitely caulk first. Once prep is done then go ahead and paint.
KD PAINTING is offline   Reply With Quote
Old 07-06-2013, 12:42 AM   #20
Rewards Points: 4,796
Originally Posted by Matthewt1970 View Post
No, most caulk actually needs to be painted. It will do nothing but collect dirt and yellow over time.
"Most" caulk? Which caulks yellow and which do not? Obviously any horizontal surface, whether coated with paint, caulk, or nothing will collect dirt.
jeffnc is offline   Reply With Quote
Old 07-06-2013, 09:31 AM   #21
Matthewt1970's Avatar
Rewards Points: 1,098
Please go back to your plumbing forum or wherever it was you came from.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
chrisn (07-06-2013)
Old 07-13-2013, 02:26 PM   #22
There are some different chemistries of caulks, and also some differences among paints. A chain is only as strong as its weakest link, so make sure the caulk sticks to what it's going to be on top of.
If you want the final appearance of a uniform coat of paint, then put the paint over the caulk, verifying first your paint sticks to your *cured* caulk.
If you want the final appearance to be that of a bead of visible caulk of some color, then make sure your caulk sticks to your paint.
Some elastomeric caulks are 100% solids, and chemically cure, which takes time (data on the label). Some are a latex-type and water must evaporate out (usually 10-40 hours) before you should lay paint over.
Pro Painter is offline   Reply With Quote
Old 07-20-2013, 09:36 PM   #23
Strong reply. I can tell you know your caulks really well.
Old 07-21-2013, 02:14 AM   #24
paper hanger and painter
chrisn's Avatar
Rewards Points: 308
chrisn is online now   Reply With Quote
Old 07-21-2013, 07:23 AM   #25
A Little Of Everything
Rewards Points: 1,364
Nice to see we have the same members engaging in the same kinds of whizzing contests as always. "Pssstttt - hey guys,
To the OP, you can caulk before or after painting. Period.
I've had to caulk - after painting - behind window casing that was installed on poorly finished drywall, leaving upwards of 1/4" gaps. Casing painted white, and white caulk. I taped both the wall, and the casing, caulked then smoothed it, then removed the tape. Perfectly straight lines on both surfaces, and a very happy home owner.
In regards to the 1x4 in your closet, if you're painting it the same color as the wall, I'd suggest either caulking it first. Or if you're happy with your sanded mud edge, don't caulk it at all.
Last edited by BigJim; 07-21-2013 at 07:40 AM. Reason: Family site deleted a few nice words
DrHicks is offline   Reply With Quote
Old 07-21-2013, 10:58 AM   #26
chrisn's Avatar
Rewards Points: 308
See post 18, this job was finished 15 days ago
Old 07-21-2013, 07:32 PM   #27
Rewards Points: 582
we would use painters caulking 1st to a nice smooth finish...then paint...ben sr
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
BM Aura paint question zfarsh Painting 3 06-11-2010 05:25 PM
exterior paint question sherlock Painting 5 07-05-2006 07:31 AM
question on crappy paint job?? Doug Crf Painting 5 05-29-2006 09:52 PM
