Caulk Question: Paint First Or Caulk First Then Paint? - Painting - DIY Chatroom Home Improvement Forum
Old 07-03-2013, 06:36 PM   #1
Caulk question: Paint first or caulk first then paint?
Hi All,
I have a coat closet that has a shelf. Some of the joints are caulked, and I will need to strip out the caulk and re-caulk.
Should I caulk the joints first, and then paint on top the caulk?
Or should I paint first, and then caulk on top of the paint?
I know it could probably go either way, but what is the correct order?
Thanks,
Drew
Caulk question:  Paint first or caulk first then paint?-download.jpg
drew2000 is offline   Reply With Quote
Old 07-03-2013, 06:58 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
You'll have a cleaner look by painting then caulking.
sublime2 is offline   Reply With Quote
Old 07-03-2013, 07:15 PM   #3
kwikfishron's Avatar
Rewards Points: 174
Are you sure about that???
kwikfishron is online now   Reply With Quote
Old 07-03-2013, 07:37 PM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Are you????
Old 07-03-2013, 07:47 PM   #5
Rewards Points: 174
Are you????
Yep...Why would you caulk trim after paint?
Old 07-03-2013, 08:10 PM   #6
Rewards Points: 13,260
Something does not look right in that picture.
It looks like someone installed the backer board, then butted the sheetrock to the top of it instead installing the backer over it.
If this was bare new sheetrock I would have suggested prime, paint two finish coats then install the backer.
If this is painting over old paint then clean off the old caulking, apply new then paint over the caulking.
Old 07-03-2013, 08:37 PM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
You look to already have a heavy bead of caulk that is cracking most likely due to something being loose or flexing quite a bit. Unless you fix it more caulk is just going to crack again. And you always caulk before you paint and if whenever possible let the caulk dry overnight.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 07-03-2013, 08:57 PM   #8
Rewards Points: 4,792
It's possible to do either. Unless you can run a perfect caulk line, caulk first and paint second. Unless you can't run a straight paint line, then you're in trouble
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
MTN REMODEL LLC (07-04-2013)
Old 07-03-2013, 09:27 PM   #9
No, most caulk actually needs to be painted. It will do nothing but collect dirt and yellow over time.
The Following 4 Users Say Thank You to Matthewt1970 For This Useful Post:
ben's plumbing (07-21-2013), cdaniels (07-03-2013), kwikfishron (07-03-2013), Will22 (07-05-2013)
Old 07-03-2013, 09:29 PM   #10
biggles's Avatar
BEHR..Deck Over experience
sorry mis threaded
Old 07-03-2013, 10:00 PM   #11
Rewards Points: 256
Hey biggles,
For concrete use self leveling polyurethane caulk.
Best of Luck
Steve
spraygunn is offline   Reply With Quote
Old 07-03-2013, 10:15 PM   #12
cdaniels's Avatar
HUH? looks like the crack is on top of a closet shelf bracket to me.Make sure the board is secured so it doesn't move anymore,get the loose caulk out and caulk then paint.Make sure the caulk is dry first.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 07-04-2013, 07:52 AM   #13
Rewards Points: 5,974
Maybe I'm wrong (probably) but as straight as that crack is it really looks like a drywall seam. A lot of guys use leftover pieces in closets. Make sure nothing is moving or loose either side of crack. Looks like a kinda big crack for just caulk.
Old 07-04-2013, 11:28 PM   #14
Roofmaster
Rewards Points: 2,172
Dont caulk that at all just trim it with a piece of 1/4 round, set and putty the nails and paint it. It looks unfinished.
Old 07-05-2013, 01:48 AM   #15
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
Paint doesnt stick to caulks like the 100% silicones, the other caulks are in my opinion somewhat "iffy" since caulk is flexible and can stretch with movement, paint wont.
RWolff is offline   Reply With Quote
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
Painting patch in bathroom ohman Painting 4 09-15-2010 11:09 PM
BM Aura paint question zfarsh Painting 3 06-11-2010 06:25 PM
exterior paint question sherlock Painting 5 07-05-2006 08:31 AM
question on crappy paint job?? Doug Crf Painting 5 05-29-2006 10:52 PM
