Caulk And Granite Countertop - Painting - DIY Chatroom Home Improvement Forum
Old 02-07-2012, 12:55 AM   #1
Caulk and granite countertop
My granite backsplash leads to a tiled wall in the kitchen and it's time to recaulk. I can't identify what type of caulk the previous owner used as it's hard as a rock - trying to use a utility knife to scrape the stuff off -- no good. However the caulk that finishes the tile and under the cabinets where the task lights are is softer. Weird. First of all, how would I remove the hard stuff without damaging the granite and secondly, what type of caulk would you recommend for replacement.
debbieindy is offline   Reply With Quote
Old 02-07-2012, 01:02 AM   #2
Rewards Points: 13,300
I use my ossilating saw with a carbide or diamond blade on it.
They may have used unsanded grout instead of caulking.
Any tile store or even Lowes or HD will have matching caulking in the flooring area in sanded and unsanded.
Old 02-07-2012, 09:36 AM   #3
Rewards Points: 150
its probably grout.......but change of plane typically calls for caulk and not grout.....perhaps thats why yours is in need of repair? Just be careful not to chip or crack the top.
organick is offline   Reply With Quote
Old 02-07-2012, 09:51 AM   #4
DIY staff
Rewards Points: 7,174
If it as hard as plastic--it's likely Poly Seam Seal--nasty stuff to remove--razor blade is the safest--
Multi-tool like Joe suggested could work--but be careful not to scratch the finished surface of the stone.
I like silicone---but it takes some learning to apply it well--
Old 02-07-2012, 11:34 PM   #5
So once I remove the old stuff, I should use silicone caulk on the backsplash (i.e. caulk for kitchen and bath)?
Old 02-07-2012, 11:45 PM   #6
Rubbin walls since'79
Brushjockey's Avatar
Do NOT - ever - ever use 100% silicone on anything that will need to be painted.
Ever.
It will repel paint- because that is what silicone does. And the resins are very hard to remove.
Stone to stone- ok- but not stone to wall.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following 2 Users Say Thank You to Brushjockey For This Useful Post:
oh'mike (02-08-2012), Workaholic (02-28-2012)
Old 02-08-2012, 06:24 AM   #7
Too Short? Cut it Again!
Ever.
I would modify this to say Do Not - ever - ever use 100% silicone on anything except as a waterproof sealer. Period. It is a sealer and in spite of marketing hype, not a caulk. Once applied, it is near impossible to ever get it all off.
Old 02-08-2012, 06:24 AM   #8
DIY staff
Sorry---thanks Brushjockey---silicone -stone to stone---a latex caulk elsewhere.
Old 02-11-2012, 12:26 AM   #9
Thanks. It is stone to stone. So the silicone and paint brings up another point -- is it okay then to paint a bathroom, then seal with silicone realizing of course you'd need to remove the silicone if you ever wanted to paint again.
Old 02-11-2012, 08:19 AM   #10
NO!
It is nearly impossible to remove the silicone. That is the point.
The Following User Says Thank You to Brushjockey For This Useful Post:
oh'mike (02-11-2012)
Old 02-11-2012, 08:35 AM   #11
DIY staff
NO!
Listen to this painter---there are wonderful paintable caulks-- avoid silicone except for special wet places like tile to tile--stone to stone---
Old 02-26-2012, 10:40 PM   #12
Thanks for the advise. I'm using a Dremel and 90% done. Wow, what a job.
Old 02-27-2012, 02:37 AM   #13
Granite is an ordinary and popularly occurring type of igneous rock. But installing it to your kitchen adds a great look and enhances the beauty of your home. A polished granite countertop adds an element of elegance to any kitchen.
Aaric williams is offline   Reply With Quote
Old 11-28-2012, 03:55 PM   #14
Should granite be polished by installers and should silicone be use between counter top and back splash granite piece? Because it seems to stain the granite lighter granite stone.
farstar is offline   Reply With Quote
granite transformations El Toro Remodeling 241 01-27-2017 11:23 PM
Granite Sink Leaking ptfrost Plumbing 5 10-04-2011 07:51 AM
custom cabinet countertop dilemma: notch it or redo? mystic_cobra Carpentry 14 05-12-2011 11:35 PM
installing granite counter ponch37300 Kitchen & Bath Remodeling 2 02-04-2009 01:10 AM
Granite not installed correctly???? debsc Kitchen & Bath Remodeling 7 02-01-2009 09:58 AM
