Caulk Every Joint On A Door Frame? - Painting - DIY Chatroom Home Improvement Forum
Old 10-04-2013, 01:26 AM   #1
Caulk every joint on a door frame?
I'm so close to finishing my master bedroom remodel I can almost taste it! I'm in the process of caulking my joints tonight before I paint the trim tomorrow. I have been caulking every possible joint, but I'm finding it quite time consuming.
I've always been told that you should caulk every trim joint. But I'm starting to wonder if I'm being too literal. Is it really necessary to caulk every joint on a door frame? Even the tight ones?
While it won't save me any time on this room, I'm planning on replacing all of the base and case in our house, including 12 more doors that I have replaced. So, is it really necessary to caulk each and every joint? I'm fine with the base and casing to the wall, but do I really need to do casing/header to the frame, the stop to the frame, corners, etc. if the joints are tight?
Thanks,
Kiel
Optical1 is offline   Reply With Quote
Old 10-04-2013, 02:37 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 504
If they are tight, there is no need to caulk them
The Following User Says Thank You to chrisn For This Useful Post:
Optical1 (10-04-2013)
Old 10-04-2013, 03:09 AM   #3
Thank you! That makes me cringe so much less when thinking of the remaining doors!!!
-Kiel
Old 10-04-2013, 09:35 PM   #4
This is a matter of personal preference. Me being me, I would walk by and look at that uncaulked piece of trim and it would drive me nuts. I even do it in other peoples houses. Ha.
If it's taking that long I suspect you're using a caulking gun and those bloody tubes. Save yourself the headache, get the small hand squeeze "red"kitchen and bath tubes from the big box store. Cut the smallest piece you can off the tip, at an angle. Then go to town.
Caulking guns are a nightmare for trim work.
Deseloth is offline   Reply With Quote
Old 10-05-2013, 03:35 AM   #5
Rewards Points: 4,796
Personally, I can't imagine caulking trim out of a tube. Not sure why you think guns are a nightmare.
I'd like to see it all caulked consistently. If it's taking you a long time, you should probably figure out what's slowing you down with your technique.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
cdaniels (10-07-2013)
Old 10-05-2013, 07:54 AM   #6
Rewards Points: 5,994
If you mean where the trim meets the wall yes caulk. If you mean like the angles at the top of door casing or in the corners on baseboard use spackle it is so much easier to sand. As for the gun and tubes they really make the job easier. A couple tips, get a dripless gun, really doesn't cost anymore, what they do is when you release the trigger they stop. the cheap ones don't, caulk will keep running out of the tube till you release the pressure.
The biggest mistake I have found DIYers make on caulking is they make the hole toooooooo big this makes it hard to control the caulk and makes a big mess. The smaller the better.
ToolSeeker is online now   Reply With Quote
Old 10-06-2013, 06:23 PM   #7
Thanks for the suggestions!
It sounds like I should just bite the bullet and caulk it all. It doesn't really take all that long I suppose, but with another dozen doors to do, every little bit counts. More so than anything else, I just wanted to make sure I didn't waste a day caulking the doors for no reason.
Thanks to everyone that chimed in!
Old 10-06-2013, 07:43 PM   #8
Jmayspaint's Avatar
Rewards Points: 534
It's good to caulk them all if you can. I don't think it's 'necessary', but it helps them stay solid looking for longer. New Trim is going to move around some over time, some of those tight joints will open up a little.
Jmayspaint is online now   Reply With Quote
Old 10-06-2013, 09:32 PM   #9
Matthewt1970's Avatar
Rewards Points: 1,098
I only caulk it if there is an actual gap or crack there.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 10-07-2013, 02:20 AM   #10
Which is why I think caulk is better than spackle.
Old 10-07-2013, 06:05 PM   #11
cdaniels's Avatar
I always caulk it all....with a caulking gun....even the 45's at the corners.They will open up over time.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following User Says Thank You to cdaniels For This Useful Post:
kwikfishron (10-07-2013)
Old 10-07-2013, 09:37 PM   #12
Davejss's Avatar
Rewards Points: 776
If you need to caulk the miter joints in your trim you need to fire the finish carpenter!
Davejss is offline   Reply With Quote
The Following User Says Thank You to Davejss For This Useful Post:
chrisn (10-08-2013)
Tags
caulk , joint , paint , trim
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 02:01 PM
Caulk this joint? scottyv81 Windows and Doors 4 08-30-2013 05:48 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Where to find correct polyurethane caulk for foundation cold joint? mikegp Building & Construction 4 07-17-2011 05:22 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
