Cant Hide Tape Lines - Painting - DIY Chatroom Home Improvement Forum
Old 03-07-2008, 11:19 AM   #1
cant hide tape lines
i am desperate-please help. i am trying to hide tape lines on several ceilings in my house. The tape lines were there when i bought my house and i have skimmed the walls several times and they are still there. I feel like I skim and skim and sand and sand and they still dont go away. i cant live like this anymore-the dust and dirt are really getting to me. any suggestions!!!
lisa68 is offline   Reply With Quote
Old 03-07-2008, 11:41 AM   #2
ceiling is one of the difficult area.... if it wasn't flat enough... there is no fix.... even it is flat enough, requires a lot of effort to do it looks good, consider it is kind of most easy to spot inperfections due to most expose sunlight/ceiling light etc...and that is why builder charge more if home owner don't want the standard stacco.... may be professional help is the only way out if really need to do it looks good...
KUIPORNG is offline   Reply With Quote
Old 03-07-2008, 12:41 PM   #3
i neglected to say that i have hired someone to do the work. he has skimmed and sanded 3x, he even painted after 2nd time and we both noticed that the tape lines were still very visible so he skimmed again. The person doing the work is someone who does all sorts of home improvements but he is not licensed. I am wondering if its his technique although i had someone else doing a plaster wall (i had a wall that looked "bumpy") and it took him forever and he really never finished the job b/c it was dragging on so long. I just dont understand why it cant be fixed. Arent there other options?
Old 03-07-2008, 01:09 PM   #4
Lisa68, are you seeing the shadow of the two pieces of drywall coming together or are you actually seeing the outline of the tape? If the ceiling is uneven, the joint line will be noticeable but not the outline of the tape. That would require floating the joint to disguise it. If you're actually seeing the outline of the tape itself, then the tape and joint step was not done correctly or not enough compound was applied under the tape and so it collapsed and got sucked down tight against the drywall pieces.
Can you give us a bit more to go on? It would be helpful.
End Grain is offline   Reply With Quote
Old 03-07-2008, 01:41 PM   #5
I am seeing the actual tape lines. It is a thick line and it goes down most of the ceiling. it looks like a bubbling-so when we try to fix it, it just keeps appearing. i am sorry i just bought this house a year ago and i am very depressed. i have never owned a house and i have no idea about any of this stuff. the ceiling does look better but when the sun comes up there they are staring in my face.
I guess a better way to describe it is -the line appears like you could take your hand and press it in. its like an outward bubble. when people have come to give estimates they say its a tape line. I just cant take it. I feel so overwhelmed.
Old 03-07-2008, 01:46 PM   #6
sounds like the tape paper is being apply on drywall with too little muds in the first installation... subsequent actiosn trying to put more muds on it will not solve the problem... the root of the problem requires to remove all the original tape paper and put on new tape paper on it with enough mud underneath....
well I am not professional though....
if you are sure your ceiling is flat .... though...
don't be depressed... there are homes which celings are wavey..... not because of taping technique... just because it is not flat....
Old 03-07-2008, 03:28 PM   #7
Penniless Parent/HO
Lisa, Are you able to upload a picture of this? I use a lamp with no shade and a 100w bulb to highlight imperfections. Can you photograph the line and upload it for us?
Mike
mikebal is offline   Reply With Quote
Old 03-07-2008, 08:43 PM   #8
yes i will upload a photo but i cant do it until monday march 11th, thanks for all your advice, please look out for it.
Blue Chalk Lines on concrete Triple L Flooring 3 10-09-2007 05:50 AM
How to use non-adhesive drywall tape? tripower Building & Construction 1 05-28-2007 09:29 AM
Can I use duct tape? Dusty HVAC 2 09-27-2006 08:28 PM
Drywall Mudding - Tape Lifting Drywall_Dummy Building & Construction 2 09-22-2005 12:03 AM
Drywall Mudding - Tape Lifting Drywall_Dummy Building & Construction 5 09-06-2005 11:53 AM
