Canelady - Painting Question? - Painting - DIY Chatroom Home Improvement Forum
Old 09-27-2008, 08:25 AM   #1
Smile
canelady - Painting Question?
Hi, I'm new to chat room. Need ideas on how to texture paint a wall after removing some old wallpaper. Only I decided to paint over the paper, top layers came off in places , so now have uneven surface. Help
CANELADY1 is offline   Reply With Quote
Old 09-27-2008, 11:55 AM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
Well you did the big no-no in painting the wallpaper, but what's done is done. Keep in mind that no matter what you put on now can still further pull up spots or bubble. Sand texture like you put on a ceiling can be very rough on a wall to brush up against and really doesn't look right. You could try a little joint compound on the spots that got removed and then paint it again. The more elaborate textures you see like swirls on a ceiling are tough and not really for a do-it-yourselfer.
Old 09-27-2008, 07:42 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
At this point it's probably best to coat with Zinsser's Gardz or an oil- based primer
Neither will further pull up or bubble
Then fill in the low spots with joint compound
A few coats if need be
Sand them smooth
Re-prime with regular latex, or Gardz or oil is OK if you've got some left
Then paint
slickshift is offline   Reply With Quote
Exterior Painting Question jmm8877 Painting 19 09-18-2008 07:27 AM
Painting a door red outside, white on the inside - quick question joeyboy Painting 6 08-26-2007 03:37 PM
Drywall Painting Question WorkOnIt Painting 8 06-14-2007 04:12 PM
