Can Zinsser Bin Be Used On... - Painting - DIY Chatroom Home Improvement Forum
Old 01-27-2011, 07:01 PM   #1
can zinsser bin be used on...
walls thats have had some patch work done? also to block the original wall color as well as seal the plaster/compound?
bbillcee is offline   Reply With Quote
Old 01-27-2011, 11:41 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
That might be overkill. A latex primer will do just fine unless you have a high concentrate of lime in your plaster.
Zinsser Cover Stain Sucks Lovegasoline Painting 38 01-20-2017 09:58 PM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Zinsser primer not drying kevinkk Painting 9 12-17-2009 09:56 PM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 11:55 AM
Zinsser Primer on Wood Veneered Furniture cupcake Painting 3 10-05-2007 03:07 PM
