Can Substitute Tsp Degloss? - Painting - DIY Chatroom Home Improvement Forum
Old 02-06-2012, 10:06 PM   #1
Rewards Points: 682
can substitute tsp degloss?
I am looking to degloss the semigloss paint inside an apartment. I would prefer to use substitute tsp to do this, since it would clean the paint same time as it was deglossing. But I am concerned substitute TSP products don't have the same deglossing properties as real tsp.
Otherwise I'm thinking of using those sanding sponges. Also I heard XIM UMA and other primers are good over semi gloss surfaces, but isn't that an expensive way to deal with the problem?
darsunt is offline   Reply With Quote
Old 02-06-2012, 10:10 PM   #2
are you prepping to repaint? XIM primers will stick to glass man, truly incredible. Dont think you can buy real TSP anymore. Deglossers are overrated anyway, scuff sand it and use a good primer.
conspikuous is offline   Reply With Quote
Old 02-07-2012, 12:07 AM   #3
Rewards Points: 682
I would rather use wet sponge sanders, I'm tired of dust. I'll check out XIM primers.
Old 02-07-2012, 11:21 AM   #4
Mr. Paint's Avatar
We have had great success with XIM-UMA. It is an adhesion-promoting primer. If you are changing from alkyd semi-Gloss to an acrylic system, this is a good bridge coat.
Mr. Paint is offline   Reply With Quote
The Following User Says Thank You to Mr. Paint For This Useful Post:
conspikuous (02-07-2012)
water substitute additive to grout for permanent sealer 4just1don Flooring 1 01-12-2012 08:44 PM
tsp cannot degloss acrylic paints? darsunt Painting 3 05-27-2011 03:59 PM
SER cable substitute for SEU brianpk Electrical 1 05-24-2011 07:58 AM
Do I really need to degloss paneling? dhoover Painting 9 09-24-2009 05:27 AM
How much do I need to degloss? sateke Painting 8 01-29-2008 08:15 PM
