Can I Texture Over Painted Concrete? - Painting - DIY Chatroom Home Improvement Forum
Old 02-14-2009, 11:58 PM   #1
Can I texture over painted concrete?
I'm finishing my basement. The foundation walls are in great shape and are painted with latex paint. Instead of attaching furring strips or framing and drywall, I'd like to just use the concrete walls. But because they are concrete, you can still see irregularities, etc, where the forms once were. Is there a thick material I can apply to the walls to cover the irregularities and smooth out the walls? Block fill is not thick enough. Joint compound sticks and looks great - but can I do that with joint compound? Or is there another material? Removing the paint is out of the question.
kp123 is offline   Reply With Quote
Old 02-15-2009, 08:59 AM   #2
Rewards Points: 506
As long as you have a sound surface, any texturing material should work fine. Textured joint compound, texture paint, whatever you like. The surface will behave no different from drywall.
SirWired
sirwired is offline   Reply With Quote
Tiling Over Painted Concrete Floor?? kiss44 Flooring 13 07-06-2011 05:41 PM
Tiling a porch over a painted concrete surface Harls Building & Construction 1 07-14-2008 08:34 AM
Texture Coating for a New Concrete Block outside Wall scholin Painting 2 12-01-2007 07:03 AM
